Results 1 to 3 of 3
    Regular Member petronas's Avatar
    Oct 2006
    377
    Series II Fog Light Wiring Harness?
    Just bought myself my third 3rd Gen Series II since 2007.
    Unfortunately this one doesn't have fog lights.
    If I were to buy fog lights for the Series II, did all the Series II (1990-1991) come with the fog light wiring harness installed or do I have to buy/source the wring harness (As well as the actual fog lights and interior switch)?
    Regular Member spacemaster's Avatar
    Sep 2005
    390
    You need a switch that has fog light button, next to the button that rase the popup headlight.
    You need to wire it, I did this, it is simple wiring behind the switch.
    After checking after checking the circuit diagram of my car model KQ, I also get it wired to the original foglight fuse slot, which was empty since foglight was not setup for AUDM.
    I can take the pic and post it, if you like.
    <cita>91 lude</cita>
    Oct 2006
    377
    Quote Originally Posted by spacemaster View Post
    That would be good if you can.
    So I bought the factory fog lights, the bracket and the switch.
  1. 5th Gen JDM Fog light Wiring harness Honda Part Numbers
    By Jet-Lude in forum Fifth Generation
    Last Post: 6th May 2010, 08:10 PM
  2. Fog Light Wiring Help
    By Gaz in forum Fifth Generation
    Last Post: 3rd June 2009, 02:46 AM
  3. Fog Light Wiring
    By JSpec in forum I.C.E / Electronics / Security
    Last Post: 14th November 2008, 09:18 PM
  4. fog light harness
    By Nola BB6 in forum Fifth Generation
    Last Post: 27th August 2005, 09:44 AM
  5. 4th gen fog light sub harness
    By ill_lude_shun in forum Fourth Generation
    Last Post: 13th February 2005, 07:57 AM
