Hey guys, new in the club here. Bought an Si thats already run 269000kms, any advice you guys have to maintain the car well?
Change the timing belt if it hasn't been done for a while or if you don't know when it's been done last, then really just change the fluids at the recommended intervals and use decent stuff if you can afford it. Fix any leaks or broken parts as they occur. The ignition system seems to be a source of ongoing woes if it's ignored too, change the plugs, leads, dizzy cap and rotor if they're getting old.
Welcome to the site too.
All those seem to be fine so far, there are leaks so need to get those degreased. It seems one of my rims is bent. Do you know where I could fine similar rims. Would be better if it matched the other 3. I've got the normal stock ones.
