    Jul 2016
    3
    Purchased VTi-R, Tacho Issues?
    Hi all!
    I recently purchased my first car (2001 Honda Prelude VTi-R, Nighthawk Black. SO EXCIXTED!)
    BUT....
    I got it for a really good price, the car is REAL CLEAN (not a mark on it), BUT the car seems to not like VTEC? It will choke at the time the second cam kicks in, thus not delivering the VTEC.
    The tacho does not work as a result, just wondering what this could be and if the Tacho actually has anything to do with it?
    The car is PERFECT besides this issue, it idles, drives beautifully, but won't let VTEC kick in.
    I was told that there is a solenoid for the VTEC that bolts to the block that can sometimes get dirty? Is this true? If not could it be a Cam Sensor, Or Knock Sensor?
    PLEASE help me!
    Thank you!
    Jul 2016
    3
    Anyone???
    You are correct, there is a VTEC solenoid on the side of the head that can get dirty and stop VTEC from engaging, this solenoid is known to outright fail too. If the cam sensor or knock sensor (or just about any other sensor) fails then it will generally throw a code. Does your check engine light ever come on?
    The tacho itself is given signal directly from the ignition control module. If the ICM is faulty then that can cause a whole host of other issues too.
    Jul 2016
    3
    ok so ill look for that solenoid and clean it. where abouts is it located? i dont think theres a sensor issue as such, there are no faults on the dash. where is the ICM located too?
    The ICM is inside the distributor. The VTEC solenoid is literally right next to it (the distributor).
  1. Replies: 3
    Last Post: 16th April 2012, 11:04 PM
  2. Purchased these today
    By trentski in forum Chit-Chat
    Last Post: 24th July 2010, 09:01 PM
  3. Purchased items
    By fkn26e_ in forum General Prelude Discussion
    Last Post: 21st May 2007, 10:34 PM
  4. Purchased a 3rd gen now need some probelms fixed hehehe
    By Connections in forum Third Generation
    Last Post: 15th February 2007, 03:49 PM
  5. H22 purchased, installment probs
    By SeLude in forum Fourth Generation
    Last Post: 19th September 2005, 03:52 AM
