Results 1 to 2 of 2
Thread: fuel pump relay
    Jun 2016
    fuel pump relay
ID:	8936 can anyone tell me if this is the MAIN/FUEL PUMP RELAY.. the fuel pump will not prime so engine wont start. the P-2 clip that connect directly to the fuel pump is getting continuity, so i need to test the main/ fuel pump relay yes??
    okay so i have tested the main/fuel pump relay as per the manuals directions double checked relay is fine.
    I have taken the fuel pump out of the tank and connected it straight to the battery.. made a continuis hummm so its working..
    I have checked all fuses relating to the fuel pump.. allgood
    i am goin to do a MAIN RELAY HARNESS TEST in the morning..
    And also check all GROUNDS..
    If i have missed anything i am open to ALL suggestions
    Sounds like you are on the right path.
    If not already fond. This might help.
    http://mustardcat.brinkster.net/p3g/.../mainrelay.htm
    The other possibility is an issue with the ignition switch. If it's not making contact correctly, it can have similar symptoms. Common fault as these age.
  1. Location of Main Fuel Relay Switch
    By CoastMick in forum Third Generation
    Last Post: 24th June 2013, 02:54 PM
  2. Fuel pump relay
    By Marco Marinelli in forum Fifth Generation
    Last Post: 29th April 2013, 01:44 AM
  3. need a new fuel filter? or fuel pump?
    By [NAV] in forum Fifth Generation
    Last Post: 19th December 2007, 05:13 PM
  4. fuel pump relay
    By NickGTR in forum Third Generation
    Last Post: 7th September 2007, 10:32 PM
  5. Fuel relay problem??
    By Dulcinea in forum Third Generation
    Last Post: 2nd August 2007, 07:29 PM
