Thread: Camber Kits
    Feb 2016
    11
    Camber Kits
    anyone got camber kits on there ludes?
    I can't seem to find any.
    Oct 2012
    58
    I'm running SPC adjustable ball joints on my 4G, more expensive but better than camber kits imo:
    http://www.tunersports.com/spc-perfo...165_p2909.html
    The Ingalls ones are meant to be good too. Just stay away from the offset cam type ones and go for the ball joint types like above. It is a fairly expensive way to go though, the cheapest I've found these for is around $80 US a corner (like above), so with shipping and the currently not favourable exchange rate you're looking at just under $500 aud to get a couple of degrees of camber correction. You probably won't find any in Australia, these cars have practically no aftermarket parts support locally.
    The question is why do you even need them? I've pretty well dumped my 4th gen (the Tein SS coils are all the way down on the front, 15mm from bottom on the back) and still I only ended up with 1.8 of camber on each corner, not enough to warrant correction. If you are after MORE camber, then I suggest you read up on how double wishbone suspension works first.
    May 2015
    23
    Probably keen on the mad stance, yo.
    Feb 2016
    11
    thanks for the help, just to run aggressive wheels. I'll have a look once i get the rims if i need them.
  1. Camber Kits
    By 01_Type_SH in forum Fifth Generation
    Last Post: 12th April 2005, 04:46 AM
  2. Camber Kits?
    By ANPatel00Lude in forum Fifth Generation
    Last Post: 17th January 2005, 11:14 AM
  3. Camber Kits?
    Last Post: 14th January 2005, 02:36 PM
  4. Camber Kits
    By Si2Fast4Me in forum General Prelude Discussion
    Last Post: 18th January 2003, 08:35 AM
  5. Camber Kits
    By indianghetto69er in forum Fifth Generation
    Last Post: 7th January 2003, 12:29 PM
