Gday guys
I currently have a 92 f22a1 4th gen prelude and plan to swap to a h22a, I have access to a 97 h22a.
I plan on using a p13 OBD1 ecu now from the information I can gather the 97 h22 uses
saturated 280/90cc injectors and the OBD1 92-96 are peak and hold 345cc injectors
is this a simple as finding a set of injectors from a 92-96 motor or is there more to converting the engine
to OBD1 also the distributor on the 97 has the same plug as a 92 h22 is there any need to change the dizzy?
if there is anything else I should know please let me know cheers.
