Results 1 to 12 of 12
    Feb 2016
    5
    F22a1 > H22A OBD2
    Gday guys
    I currently have a 92 f22a1 4th gen prelude and plan to swap to a h22a, I have access to a 97 h22a.
    I plan on using a p13 OBD1 ecu now from the information I can gather the 97 h22 uses
    saturated 280/90cc injectors and the OBD1 92-96 are peak and hold 345cc injectors
    is this a simple as finding a set of injectors from a 92-96 motor or is there more to converting the engine
    to OBD1 also the distributor on the 97 has the same plug as a 92 h22 is there any need to change the dizzy?
    if there is anything else I should know please let me know cheers.
    Oct 2012
    58
    Yes, you will need to change injectors to the peak & hold for OBD1. I got mine from a Honda Wreckers in Melbourne for $90 shipped.
    Dizzy won't need changing. See here: http://www.preludeaustralia.com/foru...1-distributors
    Vtec will need to be wired up See here: http://www.preludeonline.com/f61/how...2-swap-111568/
    Make sure the p13 is suited for the transmission you are running (auto or manual although they can be modified).
    Change the auto timing belt tensioner to a manual one & install a new belt. See here: http://www.preludepower.com/forums/s...d.php?t=229140
    Adjust valve clearances, add new fluids & you should be good to go.
    Just a note on vtec, it won't engage if you have the car in neutral or park so don't sit in your driveway revving your engine. When it does engage you will hear the exhaust note change but the actual vtec crosseover at around 4500rpm should be smooth if the car is tuned.
    Feb 2016
    5
    Cheers my friend thank you for the quick reply
    there are some mounts that need changing too.
    Feb 2016
    5
    do you know what mounts need to be changed?
    I thought the F and H mounts were the same.
    no when skinny boy upgraded his from f22 we noticed the mounts were slightly off when putting the h22 in
    Oct 2012
    58
    Quote Originally Posted by 94vtirozguy View Post
    Why forums work.
    Here's a link to skinny boys build thread: http://www.preludeaustralia.com/foru...ead&highlight=
    post 773
    Feb 2016
    5
    When changing the injectors do just need the injector itself or do i need the wiring and fuel rail as well?
    post 773
    That was an Auto vs Manual gearbox variation. Not an F Vs H issue.
    Oct 2012
    58
    Quote Originally Posted by Aura1412 View Post
    Just the VTEC injectors only, rail & wiring are the same.
  1. H22A vs H22A1, F22A1, H23A1 distributors
    By JasonG in forum Fourth Generation
    Last Post: 28th November 2011, 11:03 AM
  2. f22a1 to h22a vtec engine conversion?
    By mosab in forum Fourth Generation
    Last Post: 12th May 2009, 10:40 PM
  3. OBD2 to OBD1
    By peejayy in forum Fifth Generation
    Last Post: 15th July 2008, 06:00 PM
  4. Obd2
    By jajm in forum I.C.E / Electronics / Security
    Last Post: 5th November 2007, 08:00 AM
  5. OBD2 location
    By Mylord in forum Fifth Generation
    Last Post: 5th April 2007, 01:04 AM
