Results 1 to 3 of 3
    May 2013
    3
    Swapping engines.
    Hey guys,
    I have searched high and low for this but haven't found anything relevant to my enquiry. I have a '97 Prelude with a H22a4. It has 220,000 on it and leaks oil from everywhere. I was lucky enough to find a H22z1 for cheap with less km's and in better condition so I am gonna swap them and sell the a4 to a mate. I managed to get the ECU, wiring loom, ignition barrel and the key for it too just in case.
    Now, I know that the ECU will need to be swapped but I am confused with the ignition barrel used to start the engine. As I understand the 5th gens have a built in immobiliser from factory and I have read mixed things saying the immobiliser is in the key and ignition and the ECU. And I have read things that says otherwise.
    I just want someone who has done a 5th gen swap before to be straight with me. Do I need to change the ignition barrel too or can I use the original key and barrel on the new engine and ECU?
    Thanks in advance.
    Junior Member Zane's Avatar
    Dec 2015
    18
    Quote Originally Posted by ObsecureMeerkat View Post
    Hey guys,
    Thanks in advance.
    I believe the h22a4 and z engine blocks are the exact same bud, should be able to do a straight swap and still use your old wiring/ecu/etc. To make life easier just give your mate the replacements ecu/etc. I'm doing the same thing but vice versa since one of my cylinders hate me in my h22z haha!
    yep should be direct swapable
  1. Engines...
    By VCobra in forum Third Generation
    Last Post: 25th September 2006, 11:24 AM
  2. Swapping Engines
    By redpreludevtec93 in forum General Prelude Discussion
    Last Post: 22nd January 2003, 04:04 PM
  3. Engines
    By Relax217 in forum General Prelude Discussion
    Last Post: 29th December 2002, 11:01 AM
  4. Engines
    By btb in forum First / Second Generation
    Last Post: 23rd December 2002, 09:29 AM
  5. Modified Ss Engines
    By yosi in forum Fifth Generation
    Last Post: 21st November 2002, 11:59 PM
Tags for this Thread
