Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
    209
    Quote Originally Posted by mokhkw View Post
    I'm hoping to get access to the shop where my lude is being worked on when they have a break for xmas so I can install the headlights, OEM foggies, EL dash etc. But that also depends on work as well...
    Here's some pics of the back of the passengers side with and without the rubber boot. Hard to get a photo of the top screws inside the housing and a flexi driver would be needed - Cheap A Chips has one for $8 but they have no images so I'm guessing its just the flexi extension itself with no bits. I have a Stanley 10 Piece Flexi Screwdriver Set but they don't sell them in Oz(?) so I got mine from the UK for $30.
    If you check out eBay you can get the extension only for $3-5 ex Hong Kong
    Attachment 8784Attachment 8785Attachment 8786Attachment 8787Attachment 8788
    http://www.justparts.com/Auto_Parts/...PAIR-/20741038
    $199.15 USD. You would have to get a quote for shipping but I'm guessing it will be better than what Andys can offer, I've found them and CARiD to be the most expensive when it comes to shipping ex-USA.
    Seller is listed as Dimension Labs so maybe you can contact them about the RHS fitment.
    Thanks Mokhkw - I'm about to buy a set off Ebay I think - their price is really good. From memory Andys Auto Parts wanted about $250 US for freight - totally ridiculous! Just gotta get the Aircon repairs out of the way - I expect it's going to be $500+
    209
    Hard to get a photo of the top screws inside the housing and a flexi driver would be needed - Cheap A Chips has one for $8 but they have no images so I'm guessing its just the flexi extension itself with no bits. If you check out eBay you can get the extension only for $3-5 ex Hong Kong.
    Thanks again Mokhkw! The tool you mention - is that to loosen the fasteners; so that you can switch the lens/bulb aiming mechanism? I saw an article online once; where a guy put his headlamp shells in the oven at 121C and eventually prised them open. He then altered the cast alloy aimers inside - so that it went from JDM (RH drive) to USDM (LH drive)
    Not too sure that I'd want to go that drastic though??
    Oct 2012
    58
    Quote Originally Posted by steve-gee View Post
    From what I recall reading from the Aussie guy who installed some Depots on his RHD car ( wasn't a prelude & tbh I can't recall what car he had) he loosened the fasteners so he could get a better angle on his headlights after adjusting them as far as he could with the 2 screws at the back of the unit.
    Only thing I can't remember is if he had to do something to then keep the lenses in place so they wouldn't move after being adjusted & the bolts loosened. I expect its a tight fitment and it wasn't needed.
    Only way to swap over the adjusting plates themselves is to crack open the units by heating in an oven 1st. While is sounds drastic I've seen it done a few times but like you I would prefer to avoid that.
    I had the same Qs when I was getting the Depots about LHD-RHD fitment and got mine after reading about Aussie installing them on his RHD car.
    FYI, if you can ever organize you own freight from OS here are the ones I've found to be the cheapest:
    US to OZ - https://www.shipnex.com/default.aspx
    UK to Oz - https://www.parcelmonkey.co.uk/
    Oz to Overseas - http://www.skippypost.com.au/
    209
    Which way do you think that you'll go - just adjustment - or oven baked??
    Oct 2012
    58
    Hoping that adjustment will do the trick, if I do end up having to pull them apart then I'll do a hybrid of the Depos & OEMs with different projectors.
  1. H/Units from overseas
    By WEAPON-R in forum I.C.E / Electronics / Security
    Last Post: 29th October 2011, 04:01 PM
  2. GPS units reviews?
    By SnowWhiteLude in forum I.C.E / Electronics / Security
    Last Post: 22nd February 2010, 01:03 PM
  3. If you're in the market for GPS units....
    By ludecrs in forum I.C.E / Electronics / Security
    Last Post: 24th May 2008, 10:59 AM
  4. headlamp drama
    By Red dragon in forum General Prelude Discussion
    Last Post: 21st October 2006, 02:10 PM
  5. Headlamp adjustment for UK models
    By Al in forum Fourth Generation
    Last Post: 2nd December 2003, 11:41 PM
