Eternity - the wrong thing to be wrong about.
Thanks again Mokhkw! The tool you mention - is that to loosen the fasteners; so that you can switch the lens/bulb aiming mechanism? I saw an article online once; where a guy put his headlamp shells in the oven at 121C and eventually prised them open. He then altered the cast alloy aimers inside - so that it went from JDM (RH drive) to USDM (LH drive)
Not too sure that I'd want to go that drastic though??
Steve
From what I recall reading from the Aussie guy who installed some Depots on his RHD car ( wasn't a prelude & tbh I can't recall what car he had) he loosened the fasteners so he could get a better angle on his headlights after adjusting them as far as he could with the 2 screws at the back of the unit.
Only thing I can't remember is if he had to do something to then keep the lenses in place so they wouldn't move after being adjusted & the bolts loosened. I expect its a tight fitment and it wasn't needed.
Only way to swap over the adjusting plates themselves is to crack open the units by heating in an oven 1st. While is sounds drastic I've seen it done a few times but like you I would prefer to avoid that.
I had the same Qs when I was getting the Depots about LHD-RHD fitment and got mine after reading about Aussie installing them on his RHD car.
FYI, if you can ever organize you own freight from OS here are the ones I've found to be the cheapest:
US to OZ - https://www.shipnex.com/default.aspx
UK to Oz - https://www.parcelmonkey.co.uk/
Oz to Overseas - http://www.skippypost.com.au/
