Results 1 to 3 of 3
    Aug 2015
    3g Rear upper control arm ball joint
    I am trying to replace my rear upper ball joint on my car (4WS), they are a discontinued item from Honda and can only find them at a wholesaler which means a minimal buy of $3000. Does anyone now a place I can purchase locally
    Oct 2014
    61
    Not sure if those are the ones that people can't find anywhere, been a while since I've read up on 3G ball joints. I know Moog are good and a lot of people get it from them, spacelude from Sydney who is on here had a bunch that he was selling a while ago, he probably still has them. If not just find a local supplier. Would definitely be easier to order from overseas though.
    check if the joint itself still good if so replace the boot and grease. otherwise dig deep on preludepower.net mentioned a Canadian website, bought a set from it yrs ago
  1. Lower arm ball joint
    By Platinummale in forum Fourth Generation
    Last Post: 16th May 2012, 01:32 AM
  2. Tips on removing lower control arm ball joint?
    By new_noise in forum Fourth Generation
    Last Post: 9th February 2011, 02:15 PM
  3. lower control arm ball joint replacement HELP
    By yoda2026 in forum Third Generation
    Last Post: 24th May 2009, 06:24 PM
  4. Where Can I Get Rear Upper Control Arm Bushings?
    By Suomi in forum Third Generation
    Last Post: 3rd November 2002, 06:29 PM
