Results 1 to 4 of 4
Thread: Dyno Sheets
    Junior Member Squalled_'s Avatar
    Sep 2014
    101
    Dyno Sheets
    Hey P.A.,
    I have been looking at Dyno sheets every now and then and I was wondering about the torque readings.
Name:	Dyno Sheet.jpg
    For instance this Dyno sheet says that the LM17ER EM1 made 159 nm but on the actual graphs it has a different reading, 'Torque Rear'.
    Can anyone explain this at all?
    Lived The Prelude Life 13/11/13 - 15/09/15
    1998 Prelude VTi-R - Supermarine Blue B-84
    H22A4, 5pd - Basic 'I wanna hear my VTEC' Modifications
    Senior Member torell's Avatar
    549
    well, i cant. i tried! but... i cant.
    the dtorque figure is the one thats most likely to be close to accurate. It's derived torque and takes into account gear ratios, etc.
    882
    Ian's right with that one, it will put down a figure on the dyno but it's not always correct depending on Gear selection and Diff ratio. It needs to be a 1:1 ratio from the engine to the wheels to get the actual figure you want, which isn't always possible to do without a bit of calculation at the end!
    For example on my turbo cars' dyno it put down like 400nm of torque running 7lb of boost. I know for damn sure that the engine isn't actually putting that out .
  1. Replies: 15
    Last Post: 9th April 2012, 09:20 AM
  2. Dyno Dyno Dyno =d
    By Rolls in forum Fifth Generation
    Last Post: 16th January 2008, 02:08 AM
  3. my dyno day
    By B&W47 in forum General Prelude Discussion
    Last Post: 15th May 2007, 05:23 PM
  4. dyno
    By Bmax in forum General Prelude Discussion
    Last Post: 11th August 2005, 12:12 PM
