Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Regular Member steve-gee's Avatar
    Dec 2013
    209
    Quote Originally Posted by mokhkw View Post
    Have you considered removing the front number plate holder, mounting the plates lower on the front bar & having the LED recessed?
    If you did that you'd be able to mount the LED at the same level as the indicators/park lights (and maybe even have 2 of them to fill up the gap so to speak).
    Mount the number plates at the bottom of the bar at the same level the oem foggies get mounted.
    No - its not something I've thought of - and I don't have the number plate holder there in any case ('twas too ugly I thought). From what I can determine so far, the LED's over the plate could be just about right - giving that extra height that you'd want - to get more reach.
    Cheers
    Steve
    Eternity - the wrong thing to be wrong about.
  2. #17
    Non Honda
    Tour guide
    Jul 2019
    United States
    9
    Advice on Driving lamps not LEDs
    White are great, but for nice coloration for the whole take you generally want leds of red and green to hit at a ratio of 4:1, white:color.
    Some folks like to add blue on another switch for night time, and some also like to add magenta or blue to the white/daylight spectrum as well.
    Adding the coloration does give the tank a bit more vibrancy.
  1. Careless Driving
    By Letts in forum Chit-Chat
    Last Post: 24th March 2012, 09:08 PM
  2. 6 pin flasher relay for LED's and brake light out LED issue?
    By SnowWhiteLude in forum I.C.E / Electronics / Security
    Last Post: 16th October 2009, 01:24 PM
  3. ALB & Brake Warning Lamps
    By tonee in forum Third Generation
    Last Post: 1st June 2004, 10:01 PM
