    Sep 2014
    5
    engine doesnt fire
    Finally got the timing belt and all seals done and replaced, all back together crank and cams tdc cyl 1 all set to turn it over in excitement and engine cranks but no go, can hear it wants to but doesn't so any help appreciated im thinking sensors but not sure where to start. Thanks in advance ps can add video if needed
    fuel pump priming?
    Sep 2014
    5
    Yea all is ok accept what ever the drama is preventing it to fire n has 1/2 tank petrol
    11,093
    Recheck all the connections. Chances are it could be something you've unplugged while working on it.
    2,980
    check the ecu for any error codes is always first point of call.
    Then recheck your timing.
  1. Engine miss fire and reduction of power
    By Nimesh in forum Fifth Generation
    Last Post: 4th January 2013, 02:10 PM
  2. Miss Fire
    By Danyell in forum Fourth Generation
    Last Post: 15th June 2011, 03:13 PM
  3. Crank but wont fire
    By dandrinan in forum Fourth Generation
    Last Post: 10th November 2009, 03:03 PM
  4. fire hose nozzle...
    By torell in forum General Automotive Discussion
    Last Post: 9th March 2009, 12:09 PM
