Results 1 to 4 of 4
    3rd Generation
    76
    LED daytime running lights
    Hi all,
    Basically I bought some LED running lights and am just wondering where the place to hook the power into would be.
    Obviously power is needed from ignition, just want a neat install. All other aspects of the install I've figured out and know all the legality issues, just after info on the ign power.
    Any advice is appreciated.
    I'd pick up the signal wire from the parker lights. Then terminate the power via a relay and fuse back to +ve on the fuse box under the hood.
    No need for wiring to the dash this way.
    3rd Generation
    76
    Hey Bob,
    I had considered doing it that way but I decided that I would like the srl's to come on with the car independent of the lights.
    In that case you'll need to find an accessory wire under the dash. Easy to find one on the back of a headunit, wire to a switch, then through the firewall to a relay. The rest of the wiring and fuse etc will be placed near the front of the car.
  1. Amber Running Lights, legal or?
    By Kozman91 in forum Chit-Chat
    Last Post: 2nd June 2012, 11:21 PM
  2. LED Lights in OEM 5th Gen Tail Lights
    By tommylam2342 in forum Detailing / Cosmetics
    Last Post: 27th April 2012, 11:28 AM
  3. LED lights
    By zorro in forum I.C.E / Electronics / Security
    Last Post: 29th November 2010, 08:31 PM
  4. Daytime Running Lights
    By RickyD in forum Fifth Generation
    Last Post: 24th January 2010, 05:29 PM
  5. DRL's, daytime running lights...
    By SorrGwa in forum Fourth Generation
    Last Post: 25th February 2005, 01:56 AM
