    Jan 2010
    115
    Upgrade front brake, need hubs change?
    Hi all
    I got a prelude si 1997 which have 260mm rotor and 4x114.3 PCD.
    I just want to upgrade to bigger brake (prelude 94 vtir 292mm rotor and keep 4x114 pcd)
    But do i need to get the capiler, rotor and the hubs or i only need the rotor and capiler without changing the whole front hubs and whole metal thing?
    Cheez
    282mm not 292, you dont need to change the hub just need to cut a small corner off the metal shield to accommodate the bigger caliper and possibly bent it a bit to avoid rubbing with the rotor.
    You may already know. But just to point it out, you will be needing the 4th gen Vtir rotors, not the 5th gen ones. Due to the 4x114.3 PCD.
    Calipers can come from either the 4th or 5th gen.
    Jan 2010
    115
    Thanks so much! But do i need the bracket as well?
    Which bracket?
    The caliper is everything fitted to the hub. You need the whole caliper.
  1. Brake UPGRADE
    By Avi Atzil in forum Suspension / Wheels / Tyres / Brakes
    Last Post: 7th February 2012, 09:50 PM
  2. Brake upgrade?
    By Prelude Misfit in forum Third Generation
    Last Post: 18th June 2011, 09:25 AM
  3. Brake Upgrade.
    By wittles in forum Suspension / Wheels / Tyres / Brakes
    Last Post: 24th January 2010, 02:40 PM
  4. brake upgrade
    By d_soljah in forum Suspension / Wheels / Tyres / Brakes
    Last Post: 15th September 2008, 11:47 AM
  5. Brake Upgrade...
    By eightyfivelude in forum First / Second Generation
    Last Post: 15th December 2002, 12:33 PM
