Results 1 to 8 of 8
    Oct 2013
    21
    Rim/Tyre Confusion
    Hey Guys,
    So I've been reading up on the recommended rim/tyre and offset guides on the forum. Seems like there is alot of different opinions on what you can and can't run as i noticed on some of your build threads.
    I was wondering if it would be a good/bad idea to run 17 x 7.5 +38 offset with a 225/45/17 tyre on my 5th Gen Vti-R. Also, I plan on lowering a little maybe about 1.5 inches, with coilovers. Would this scrub/would i need to roll fenders?
    Cheers
    Senior Member Sean628's Avatar
    Mar 2011
    945
    1.5 should be ok consider the tyre size is not much bigger than stock not sure the offset on 5th gen though, might poke out a bit not sure
    Silver Member diMii's Avatar
    Oct 2008
    --Australia--
    1,326
    That is a perfect size
    Oct 2013
    21
    Hmmm tempting, anyone with a 5th gen that can vouch they will fit?
  5. #5
    Oct 2008
    --Australia--
    1,326
    I have a 5th gen in my garage right now with 17*8.5+35 with 225 on it, no rub. Like I said dude perfect size
  6. #6
    Oct 2013
    21
    Wow that's sick man. What wheels do you have btw? Are you low/did u roll your guards?
  7. #7
    Oct 2008
    --Australia--
    1,326
    not my car customers car, they are generic wheels, and yes his gaurds are rolled and pumped slightly but with 7.5 you would be more than fine, and yes his very very low, but height does not change the fact of it rubbing or not thats more to do with stiffness. 7.5 is not a wide wheel for a prelude, the standard wheels are 6.5 +45 or so and they sit in heaps.
  8. #8
    Oct 2013
    21
    Thanks for the advice man. Gives me much more confidence in deciding which wheels to get now
  1. confusion
    By Clean McSheen in forum Site Help / Suggestions
    Last Post: 13th December 2010, 04:27 PM
  2. weather shields & 18" rim tyre profiles for 4th gen
    By zanza34 in forum Suspension / Wheels / Tyres / Brakes
    Last Post: 21st October 2010, 01:23 PM
  3. Confusion over rims
    By basik in forum Suspension / Wheels / Tyres / Brakes
    Last Post: 10th December 2008, 04:02 PM
  4. confusion about stuffs
    By 55yenz in forum I.C.E / Electronics / Security
    Last Post: 22nd March 2007, 09:29 PM
