    Jan 2010
    115
    Prelude 97si 4 stud brake rotor =92-96 prelude brake rotor?
    Hi all.
    Recently i need to replace my rotor but i cant find any info about the rotor size?
    All i know is 4x114 same as 4th gen prelude.
    Can anyone confirm if Prelude 97si 4 stud brake rotor =92-96 prelude brake rotor?
    Cheez
    11,093
    Keep in mind the 4th gen rotors come in 2 sizes.
    282mm on the Vtir
    260mm on the S and Si.
    I believe the 4th gen 260mm 4x114.3 rotor is the same as the 5th gen Si 4x114.3.
    Brembo are listing them as the same part numbers.
    yes bobs right, they are the same
    Jan 2010
    115
    Thz for the quicknreply!
    But the rear is 260mm as well as front?
    So if i get the 4th gen prelude si rotor i would be fine right?
    282mm on the Vtir
    11,093
    Rear rotors
    All the rear rotors on the 4th and 5th gens are the same. Regardless of model. All 260mm, but non ventilated at 10mm thick.
    Front rotors
    In 4x114.3 PCD, you have the 260mm x 23mm for the 4th gen S and Si and also the 5th gen Si.
    Then there is the 4x114.3 PDC, 282mm x 23mm for the 4th gen Vtir.
    And the 5x114.3 PDC, 282mm x 23mm for the 5th gen Vtir.
    Savvy?
  1. Brake Rotor Issues
    By T-Marley in forum Fourth Generation
    Last Post: 1st October 2005, 03:20 AM
  2. Brake rotor vendor
    By kobiwan in forum Fifth Generation
    Last Post: 14th April 2005, 12:27 PM
