Results 1 to 7 of 7
    COTM - May 13 Pacman
    COTM - May 2013 Pacman
    MODIFICATIONS
    Engine:
    Stock H22a1
    AC high volume fuel rail.
    RC 650cc injectors.
    Nissan GTR R34 fuel pump.
    KMS Engine Developments EGR deletion plate.
    Custom Stainless turbo manifold. (Port matched, tuned length, concentric firing order into merge collector, ceramic coated)
    Garrett GT2871r water and oil cooled ball bearing turbo. compressor housing has a/r .60, exhaust has .86. With internal wastegate,
    KLS adjustable waste gate actuator, currently running 10psi.
    NRG engine damper used to delete front engine mount.
    Custom 3 inch dump pipe, with separate waste gate chamber.
    Magnaflo 200 cell 3inch high flow cat.
    Exotic exhausts, custom mandrel bent 3inch system, to twin 2.5 inch with twin cannon mufflers.
    Custom stainless hot and cold induction pipes.
    Turbosmart 34mm dual port Kompact BOV.
    Liquid to air Intercooler with 10 x 4 x 4 inch core, with 20 x 12 inch PWR aluminum heat exchange, and 12 inch electric fan.
    Greddy Trust timing belt,
    Gates Racing balance shaft, A/C, power steering belts.
    Skunk2 adjustable cam gears.
    Koyo 56mm dual core aluminum race radiator.
    Gates Racing 170F (low temp) thermostat.
    forbidden Motorsport cooling plate.
    KLS sandwich plate and oil cooler, -10 stainless braided oil lines.
    Drift blue anodized catch can and stainless braid lines.
    P28 ECU modified for Hondata S300 ECU
    Innovate Motorsport Lc1 ride band O2 sensor.
    F1. Stage 4 copper ceramic cushion button clutch.
    F1 11.5 lb single piece chrome molly flywheel.
    110fwkw (147.5 fwhp) when car was N/A...
    160fwkw (214.6 fwhp) @ 10psi. Tune to come… (watch this space)
    Suspension & Brakes:
    D2 Racing fully adjustable coil over shocks and springs.
    Selby 24mm front sway bar.
    Selby adjustable rear sway bar.
    SPOON. Front strut brace.
    SPOON rear strut brace.
    Tanabe Sustec front underbrace.
    Goodridge stainless braided brake lines.
    Slotted and cross drilled rear rotors.
    Slotted front rotors.
    17' 3 piece Racing Hart rims. 215/45/17 Bridgstone Potenzas.
    Front Traction bar setup. (to be fitted)
    Exterior:
    Custom layup front bar with Di-Noc carbon center and aluminum sacrificial scratch plates, commercial layup rear bar.
    Modified custom layup Black Widow side skirts.
    Clear Plexiglas GT style rear wing, with custom LED for legally lit wing,
    OR. 2 foil carbon drag wing. (currently running with the Carbon wing)
    Angel eye head lamps, clear parkers and side repeaters.
    Clear Altazera tail lights. White LEDs all round.
    7 color under body LEDs.
    Carbon door handles.
    Di Nock carbon eye lids.
    Interior
    Custom red and black interior retrim.
    Red Mugen floor mats.
    Red Forza sport seats,with carbon backs.
    5th gen Moon roof conversion.
    High mount rear brake light.
    Forbidden Motorsport short shifter.
    A pillar Boost and oil Air Fuel gauges.
    4 point Blue Racing harnesses.
    Carbon door sills.
    Carbon Inner mirror trim
    DC2 Itr Airbag steering wheel.
    Sound
    7' LCD Eonon touch screen head unit. 5x65w output.
    Alpine SPX-17REF front components with Alpine x-overs.
    Hertz 6 inch rears.
    Twin matching Fusion 600w 4 channel amps.
    2 Alpine type S 600w 12 inch subs.
    AER Pro farad capacitor,
    7 inch LCD monitor for rear seat passengers.
    7 inch LCD monitor between amps in the boot.
    QUESTION TIME.
    What's you're Favorite Mod?
    Defiantly the suspension set up. No use having more power if your suspension can’t handle it.
    If you had your time to redo everything again what would you do or not do?
    The Manifold. Spent way too much money on the manifold. Then again, I think it’s just about perfect.
    How long have you had the prelude for?
    The car was given to me about 6 years ago by my father.
    If you could have another Model Prelude - What would it be?
    Any. If it was a good clean car, I’d have any gen Prelude. (Yes guys Even a 5th gen.)
    How long did it take you to decide what Mods to do?
    I always wanted to modify everything. My car is not about subtle choices. OBVIOUSLY.
    Where did you get your ideas? Where does my inspiration come from?
    The first Heavily modified Prelude I ever saw up close belongs to Nghai Lee. I loved it and decided to build my version on his car.
    Did you do majority of the Mods yourself?
    Pretty much. Except the welding.
    What Mods did it have when you bought it?
    King springs and koni shocks. It also had the Heart rims, which I will never change. I love them.
    Has it been Dyno'ed? What's the result?
    When it was N/A, it won a dyno comp for FWD cars. Won Highest power N/A at 147.5fwhp
    At last tune it made 214.6. but it has had a new turbo and exhaust since then.
    Next Mod?
    Redesign dump pipe, Individual coil packs, New fuel system (Wallbro 255 lift pump, swirl pot and Bosch 044, Sard FPR. That’s the immediate list anyhow.
    Future Aspirations for Prelude?
    Built motor, New paint work. Drive da ****a around lots…???
    How do you find the police are towards your lude? Any stories?
    The only time I’ve had a problem with the police in this car was when I was a smart ass to him. My own fault. Usually I have no problems. Even when I have been pulled over without reason, the officer saw that I was “mature” and said, “Sorry mate, was expecting some young wanker!”
    What a sexy car...!
    Well, I'd like to thank Bob for setting this up. (thx Bob)
    Thanks also to those who voted, not just for me, but anyone who voted. At least you got involved.
    And lastly, but certainly not least, I'd like to slag off at all those oxygen thieving keyboard warriors who have been going on and on about wanting this, then totally ignore Bobs effort.
    Everyone wants this, we have to get behind Bobs effort guys, pull your collective heads, out of your collective asses....
    End rant...
    Once again, thanks Bob.
    Great work Bob, and congratulations Pacman! Deserved winner.
    Vtir
    Mar 2009
    443
    very true, excellent work bob keep up the great work. congrats steve just waiting on the front page change to be official lol
    ATTS
    348
    End rant...
    Great work bob for getting COTM going again and congrats to pacman!
    Quote Originally Posted by Kozman91 View Post
    I didn't choose the lude life, it choose me
    If it's got wheels or floats, if its got tits or wings, it's only ever going to cost more money.
    Very cool, can vouch for the suspension setup, awesome stuff!
  1. Pacman's Progress thread.
    By Pacman in forum Boost
    Last Post: 8th June 2014, 09:19 PM
  2. Pacman's Progress thread.
    By Pacman in forum 4th gen
    Last Post: 22nd November 2011, 08:56 AM
  3. Replies: 11
    Last Post: 25th January 2011, 10:06 AM
  4. Pacman's G4
    Last Post: 30th September 2009, 08:57 AM
