Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 77
    254
    Little lude in the background
    Sent from my iPhone using Tapaslut
    Senior Member Baz's Avatar
    Aug 2009
    790
    how do you get sponsorships for backyard project builds? or are they just paying you to put stickers on your car as a driving billboard?
    254
    Quote Originally Posted by Baz View Post
    met the owner of carbon plus through that evo, was fitting a front splitter and rear diffuser at time of photo, then turns out he has a mx5 yada yada, lemme know when so ye, just happened really.
    254
    Dimii. I plan to only scrape the surface like you say but there are 83mm (OE size) and 83.5mm pistons as well as 84mm etcc....
    Have you measures you bores, I doubt they are 83 from factory after so many years. If so you have to get it machined then so .5 over
    254
    Damn. Ill bring my bore measurer home tonight and check em
    Yeah make sure its accurate don't go using a manual vernier lol
    254
    Haha mechpro ftw
    Got the new welsh plugs and honing tool today so the plan this weekend is to hone the block and put new plugs in. What do you guys reckon the most effective way to clean the oil galleries and water jackets is?
    Edit: other than acid dipping.
    If you've got the welsh plugs out, get a high pressure water blower, like a Gerney and blow it all out, its what I did recently to clean out the water galleries in the 5m. For the oil I suggest leaving them til the engine is back in the car, then doing a oil flush with some shitty cheap oil.
    Jul 2011
    175
    Easiest way to clean the water jackets is with a Karcher or similar high pressure washer.
    If you've got the welsh plugs out, turn the block upside down on a engine stand and go for it.
    Stick the nozzle into every single outlet you can find until fresh water pours out, the high pressure cleans out all the crap from every single spot possible.
    The best way to clean oil galleys is just good old air pressure from a compressor, the little brushes the guys use for cleaning guns (a kind of bottle brush with a long stem) and some degreaser.
    I use a air blower with a rubber tip, that way you can press it in tight to an oil hole and get full pressure through the galley, spray degreaser down the hole and scrub with a brush and blow it out with the air.
    Only clean out the oil galleys like this if you have the whole engine stripped down though, you don't want that crap sitting in around the bearings and stuff........oh, and glue in brass welsh plugs with araldite or some other epoxy glue, don't use steel ones.....defies description why people use steel ones when brass cost the same
    254
    Itsmee cheers dude and ye always glue em in at work as well.
    Koz
    I wouldn't risk flushing carbon coated oil thru my new bearings no offence
    Dimii question about the honer I bought. They said it is around a 400 grit but the pack it came in just says 'medium grit' you reckon that will do? It's not a dummy brush style it's a three leg one.
    It has to say a grit somewhere, should of gone to Bursons they have every grit available. But anyway medium should be fine doesn't go more than 800 anyway so yeah.
    254
    Gives me nothing. I've checked it inside out. Ill chuck up a photo in a bit
    254
    so ive got either 83.01 to 83.02 across all four through the whole cylinder, looks good to me
    Well then you have to get them machined .5 over over for the pistons and rings lol
  1. full tank
    By MrDOHC in forum General Prelude Discussion
    Last Post: 26th February 2007, 04:12 PM
  2. Full re-spray!!!
    By andylena in forum Fifth Generation
    Last Post: 4th September 2006, 09:49 PM
  3. Full-Race
    By Sc45ott in forum Boost
    Last Post: 13th January 2005, 09:35 AM
