Results 1 to 5 of 5
    Junior Member RSkoljarev's Avatar
    Oct 2008
    149
    Question Leaking Brake proportioning valve
    It seems that my car likes to have problems with things that are hard to find....
    My brake proportioning valve is leaking; apparently it is a discontinued component even when some US web sites have a price next to them.
    Part numbers are:
    46210-SB0-003 replaced by 46210-SF1-003
    46210-SF1-000 replaced by 46210-SF1-003
    46210-SF1-003 discontinued
    Does anybody know if there is any other Honda part compatible?
    Did anybody have this problem?
    Oct 2008
    149
    Silver Member diMii's Avatar
    Oct 2008
    --Australia--
    1,326
    just get one off a wreck, im pretty sure you could use a 4th gen non abs one, looks the same
    Sep 2015
    --Australia--
    1
    Hi I'm new here. I have the same problem with proportioning valve. Can you please tell me how did you fix this problem? I've got second hand proportioning valve and I changed it but it is the same thing, leaking again on same place?
  5. #5
    Junior Member Saywhat's Avatar
    Jan 2016
    18
    You have a few options first is buy a brand new one from Honda or similar might be $$$ but worth it.
    Second hand again bit of a gamble but might work out great or dead?.
    Third Modify mangle another pop valve from a gen4/teg/civic non abs.
    Last of all replace the o ring seal your self just make sure the o ring seal material is compatible with brake fluid. You could always get a brake shop to do it for you as well.
  1. Brake fluid leaking from the reservoir
    By SnoopDouggie in forum Fourth Generation
    Last Post: 11th April 2008, 12:01 AM
  2. Random brake warning light and park brake on
    By rogue_mc in forum Third Generation
    Last Post: 28th September 2007, 06:52 PM
  3. Valve stem seals or just Valve Adjustment?
    By PreludeSiRFL in forum General Prelude Discussion
    Last Post: 12th February 2005, 09:48 PM
  4. ABS, Brake & Parking Brake Light Fault
    By tonee in forum Third Generation
    Last Post: 4th April 2004, 11:28 AM
