Results 1 to 9 of 9
    Nov 2012
    63
    Low RPM when idling
    So we have encountered my first major issue with the 3G. After taking it for a good 1 hour drive the car is starting to have an issue with idling at very low RPM (About 450 - 500 RPM). The car shakes in a similar way to what it does when the car is about to stall.
    Im seriously concerned about this and I've done some searching on the web but cannot find anything to help. So I'm asking PA members!
    So do you guys have any idea as to what is causing my low RPM when idling and how I should fix it? Or should I just pay the cost of sending it to a mechanic?
    mine idles at 250-300 according to the tachometer and shakes a lot but that's because the meter's off and engine mounts broken, the actual idle was ok, check your timing and adjust idle screw first
    Nov 2012
    63
    I might need a new timing belt...
    My engine mounts aren't broken though so I don't really understand where its coming from. It almost feels like it misfiring...
    What Sean said, do that first.
    Also try bleeding the coolant screw, if there isn't a steady stream of coolant that too can cause idle issues.
    Is the idle fluctuating or just low?
    Nov 2012
    63
    Just low. Its in the mechanics now. Guy said he will give me 3 quotes.
    1 to get it roadworthy
    1 to get it roadworthy and fix a couple of things (New timing belt etc)
    1 of a full upgrade to the car (New brakes, dics, cold air intake, all that cool stuff!)
    So I'll have a few options of what to do with the car, all of which would at least fix my idling issue (Mechanic said he noticed it and that he can do it for free as its a fairly easy job.) CONTACTS MAN!
    Junior Member lovelyqoo's Avatar
    Feb 2010
    149
    any follow up on this? I'm having the same issue; it idles and goes up to 500rpm then back to 0 and so forth. Bled the coolant valve and got a steady stream. Where is the idle screw located?
    idle screw is at the top of the throttle body, slightly to the left if you are looking at it head on, should be very noticeable, has a notch for a flat head screw driver, remember to put a jumper wire into your diagnosis plug first though and unplug your eacv.
    Also if it keeps happening try swapping your eacv or fiv.
    Regular Member spacemaster's Avatar
    390
    Spray and clean throttle at the same time will smooth your idle
    <cita>91 lude</cita>
  1. Strange noise at idle and low rpm...
    By jackazz in forum Fifth Generation
    Last Post: 11th June 2005, 01:37 PM
