Page 1 of 4 123 ... LastLast
Results 1 to 15 of 55
    254
    Rydah's summer turbo project progress thread
    So as the title says, by the end of summer i want to have a basic turbo set-up with a worked head
    PLANS:
    buy h22a head, get it ported and straitened
    new:
    valves
    retainers
    springs
    guides
    seals
    cams
    edit:
    ARP head studs
    new headgasket, maybe de-comp plate?
    how should i go about doing all of this?
    i already have the turbo and exhaust made up to be a straight bolt on when i drop the head in but what have you guys found best/most recommended for going about this?
    Forget the valves, springs, retainers, de compression plate etc
    Instead get the head ported and polished and port matched to the manifold. Then get a bigger throttle body and have it port matched.
    While the motor is apart put in mahle pistons and drive it like you stole it!
    The stock head is perfect for turbo as is. Cams are a waste of money.
    254
    sounds good, in that case, well i dont need to wait till summer is over, what should i get in that case? im still after a daily driver as i stay under 4 grand on a daily basis but i want booooost for fun
    Spend the money on a goods ecu setup like hondata or Neptune.
    ^^^Solid advice
    254
    Quote Originally Posted by SnowWhiteLude View Post
    ^^^Solid advice
    where to acquire ecu? better second hand or should i buy new?
    should i at least say change my head studs to ARP? or i can just "basically" bolt turbo on ?
    wouldnt there be some fuel issues? pr manifold vacuum line problems?
    I think you'd have to at least upgrade your pump to a walbro 255...
    ^^^ and bigger injectors
    you can get 2nd hand hondata and neptune ecu's, but some of the chipping on these are pretty crap. I bought one on here that I had to do quite a bit of fixing on.
    It's probably better to buy from a reputable seller like xenocron.com
    Yep, bigger injectors, fuel pressure gauge and pump are all required.
    254
    these i am are assuming insurance for the car to work functionally?
    if so then, yes it is a must.
    so,
    walbro 255 pump
    fuel pressure guage
    "zenocron.com" ecu??
    injectors? what cc? any particular brands to stear clear of?
    Insurance? no. They're a requirement. Turbos need more fuel.
    The gauge is insurance for when you're on the dyno and need to diagnose a problem.
    Pick the CC of injectors you require to make the power you want to make.
    254
    im happy with 160 ish fwkw, nothing more than 200fwkw, im not to sure on what cc to get? how do i calculate/choose? what is it based on?
    For that sort of power i would look at around 600cc minimum.
    254
    sweet, all brands basically the same?
  1. Replies: 1085
    Last Post: 14th October 2014, 06:46 PM
  2. Rydah's progress thread
    By rydah in forum Boost
    Last Post: 9th January 2012, 01:03 AM
