Results 1 to 10 of 10
    Silver Member tommylam2342's Avatar
    Feb 2012
    1,222
    Easiest Accessible Firewall from the driver side?
    I just got my fog lights, but the one thing that is REALLY bothering me is where I'm supposed to put the wires through from under the driver side to the fogs.
    PICTURES would be really helpful here. Thanks. Also what size screw would I need to install the fogs themselves? Because the ones that came with the fogs don't even bloody fit!
    Support Me & the JDM Community By Liking Us! >>> "JDM Obsession!"
    Junior Member paddo17's Avatar
    138
    Umm .5mm the bolts are I think?? From memory as for the cable ill get a picture tomorrow but top left corner in the engine bay remove the fuse box and under it is a hole that goes to straight above the fuse box in the car if need be cut a small hole in the rubber to fit the cable through but make sure to cover it back up.
    You should be able to just feed it through and bam problem solved. There may be other options but I did mine this way.
    138
    Here is the fuse box.. Remove it
ID:	7387I can't remove mine right now but you can see I have taped mine up but that is where the wires should go through..
ID:	7388 And here is inside the car. You can see where I have brought the cable through in the background.
    Feb 2012
    1,222
    Ye that's where I was also planning to run my wires through, but I have a few questions first.
    1. Is it just three screws to remove the fuse box? Or are there more?
    2. Should I run the cables from the outside to the inside? Or other way round?
    3. How in the hell am I supposed to get my hand to that point inside the car? Isn't it like behind the wire attached to the accelerator or something?
    138
    Quote Originally Posted by tommylam2342 View Post
    1. There is only 1 screw from memory, the back is not held by screws.
    2.run from outside in. It is a lot!! Easier
    3. Yes it is and I'm 6 foot 5 and have massive hands so if I can do it anyone can. Helpful hint is to attach a piece of wire to the cable your putting through so you have something easier to pull on.
    Feb 2012
    1,222
    Quote Originally Posted by paddo17 View Post
    Alright. Seems pretty straight forward. I shall continue on this project either tomorrow or the day after. Now that you've explained it sounds easy enough Really do appreciate your help mate
    138
    That's cool mate. Best of luck with it all.
    Feb 2012
    1,222
    FINALLY!!!! Took me about 2 more hours to get this thing installed. Looks so easy, but you have to take your time to do it right Really do appreciate the help man
    Paddo nailed this. Exactly how I did my foggies.
    Junior Member GordonB's Avatar
    Blk Leather
    May 2015
    3
    Behind the fuze box is the easiest way to get through the firewall on the drivers side. Once the retaining bolt is undone be carefull with the two clips at the back of the
    box and it lifts straight off. Just to let you know, if you are installing driving lights on a BB6 there is a wire pre run from the factory. It starts inside the drivers side footwell fwd of the fusebox and exits just behind the drivers side indicator. I used it when I put driving lights on my Prelude. Located it after reading a "fog light install" thread, found after a google search.
  1. smoke from driver side
    By Akatsuki in forum Fourth Generation
    Last Post: 22nd August 2008, 02:10 PM
  2. driver side fender
    By redludesi in forum Fourth Generation
    Last Post: 11th February 2005, 08:21 AM
