Originally Posted by
PHM91 on ozHonda
paper clip does the trick
engine off, disconnect the yellow plug connected to fuse box under dash (yellow 2wire plug),
unfold the paper clip so it looks like a skinny U,
connect the paper clip into the yellow plug( one end in each wire)
trickest part of it all
(turn the car onto ACC the SRS light will be on, then the SRS will turn off, when it turns off pull the paper clip out,
then the light will reappear, when it reappears insert the paper clip back into the wires)
then the SRS light will turn off
Now turn off your Ignition off and your SRS will be reset
reconnect the plug back into the fusebox
and now start your car (the light should be gone)
