Page 1 of 5 123 ... LastLast
Results 1 to 15 of 63
    PJF_Lude new progress thread
    Due to a lot of old info, and some bad info from a few members cluttering the good info, I've deleted my old thread and am starting fresh.
    Back story first:
    Bought the car in 1997, was 100% stock with an auto box, for my now ex to drive to work. When we split in 2007, I kept the car and started this project.
    2008 saw the first turbo setup, with a small T25 on the stock engine. Over a 4 year period it saw 3 different turbos, ultimately with a GT28 bal bearing turbo from a JDM S15 silvia, running various levels of boost between 6 and 10 psi. This setup lasted until around April last year when the engine failed after I installed a new ported head.
    Being a bit of a collector of parts, I had a spare engine to throw in, but ultimately decided to fully build the old engine.
    I dropped off 2 blocks and 2 cranks to my engine builder for him to pick the parts he liked best.
    Did a little shopping and bought some new bits and pieces.
    Carrillo PRO-H forged con rods - pretty much the strongest forged ally rods you can get.
    Wiseco forged pistons, 20thou oversize, and slightly reduced CR 9.0:1 (sent off to have a low friction coating put on the skirts)
    All gaskets genuine honda except for Cometic 3 layer MLS head gasket.
    New genuine Honda oil pump
    Gates timing belt and tensioner kit.
    ARP head stud kit
    ARP main stud kit
    Engine builder told me it would be 6 weeks, ended up being closer to 9 months. But the engine got the full treatment. Each bore machined, with torque plate attached, to exact size for individual pistons, mains line bored square to deck. Deck machined to suit MLS gasket. Bottom of bores notched for clearance for the larger con rods.
    The head had previously been ported and rebuilt, but was stripped down, cleaned, and rebuilt again to make sure everything was spot on. The lower part of the intake had been previously ported to suit the head, but the upper plenum was still stock. We ported it to suit the H22 throttle body, we even experimented with various spacers and even removing the IAB plate completely, but found that Honda has done a pretty good job, so it is stock, and with the air being force fed it doesn't really make much difference anyway.
    Our calculations show that even with the port work the cams will work reasonably efficiently up to around 350hp with a turbo, so I've left them stock. I'm not chasing anywhere near those sort of numbers, so no point reducing drivability off boost with different cams.
    Current turbo setup:
    GT2871R - ball bearing turbo, good for over 450hp, so again, plenty of head room for my goals.
    Precision 440cc injectors, I have 680cc injectors sitting on the shelf ready to be fitted.
    Walboro high volume fuel pump.
    Standard fuel regulator works fine, so it has been left as is.
    Currently running Crome Pro on JDM P08 ecu, but will be changed to NepTune P06 ecu, modified for IAB, and PWM boost control
    Anyway, on to the pictures.
    Every one knows what the car looks like (been COTM for 3.5 years ) but here's a couple more in case you never look at the home page here.
    New pistons, with anti-friction coating.
    Carrillo rods
    and the notching in the block for rod clearance
    Rebuilt head
    ARP goodies
    Head studs
    Main studs
    Injectors
    Cometic headgaskets (yeah, I've used a few, I refuse to use more than once)
    The 2871R
    compared to one of my old turbos
    The engine almost ready for installation
    Suspension and brakes:
    Been through a few different setups now, but current setup is
    F2autolife coilovers
    Superpro and prothane poly bushings
    I also have whiteline heavy duty sway bars both front and rear.
    Cusco strut braces front and rear.
    Recently picked up these. 4 piston caliper, 310mm 2 piece rotor. Not yet fitted.
    Interior.
    JDM foot lights
    Custom door trims, DC2R MOMO steering wheel, DC2R shift boot and shift knob, NSX electric seats.
    NSX seats again, centre armrest.
    I've also done a series 2 dash conversion, map light, power folding mirrors.
    Transmission
    In progress:
    D2M5 series 2 manual gearbox
    Currently rebuilding with all new bearings, seals and synchronizers.
    DC2R helical LSD
    Slightly larger series 2 axles and front spindles/hubs.
    Diff:
    New bearings and synchros
    Both shafts all wrapped up to keep them clean until it gets reassembled.
    the leftovers
    Just waiting on a bearing shim for the diff and it'll all be back together.
    nice!
    Awesome Prelude Ian. I'm nots sure if this was covered in your previous thread, but how much power are you putting out with your setup? I'm sure a lot more has gone into this than you have mentioned in this thread only!
    This thing is all class....
    those seats are so comfortable , i still liked the old thread ian but this one is way more fancy and pretty . i had to walk away and control myself alittle with the those connecting rod pics , you know how much i love them .
    Vtir
    Mar 2009
    443
    reading all this and looking at this pics makes me think.... why am i reading this in a lecture.... i now have no idea what this guy is talking about it lol
    i should be ordering parts i need to be relocating things motivation is back!! cheers ian lol
    when will you finish up the gearbox mate?
    Feb 2009
    472
    NSX Seats D:
    Everything buffs out with the right amount of elbow grease
    Thing of beauty.
    This car is built of awesome...
    Senior Member Tommzor's Avatar
    Oct 2010
    517
    My first inspiration right here.
    Grip > Slip.
    1989 Honda Prelude SI.4WS, Pheonix Red - SSV-135 / PR3LDE - Rust in Peace.
    1989 Honda Prelude SI.4WS, Polar White - PR3LDE - Rust in Peace.
    1987 Honda Prelude JDM SI.4WS - Granada Black - Work in progress.
    2002 Mitsubishi Lancer CE Coupe - Amethyst Black Pearl - Daily.
    Can u let me know what r the numbers in the photos?
    SPF2131K
    SPF2132K
    Are they all you need? Looking for a set myself now, thanks Ian !
    Quote Originally Posted by Gee View Post
    Yeah, there has been a lot of hard work and trial & error along the way, but for sake of clarity, this is how it sits now.
    It's 100% street tuned by me, and hasn't been on a dyno in it's current form, if I had to make a conservitive guess, i'd say between 220-240 hp at the wheels on 8psi. Free time pending, I'm hoping to get it on a dyno for a 1 bar tune before the end of the year.
    Quote Originally Posted by Raysian View Post
    Gearbox will hopefully be finished in the next week or so, but i need to choose a clutch yet, so will be a little while before it goes in.
    ... with the help of awesome friends. Thanks mate.
    SPF2131K
    SPF2132K
    Here's the full list:
    Front
    Lower control arm inner - SPF2131K
    Lower control arm outer - SPF2132K
    Upper control arm inner - SPF2061K
    Radius rod - SPF2129K
    Sway bar link bushing - SPF0904K
    Rear
    Lower control arm inner - SPF2133K
    Radius rod - SPF1767K
    Sway bar end link - SPF1531K
    I haven't bought the radius rod ones yet, but I need to. All others are what is in the car now.
    Don't bother with the prothane stuff, despite all the discussions of washers and spacers over on pp, they still don't fit propery, the superpro ones fit perfectly.
  1. My Progress thread
    By manolii in forum 5th Gen
    Last Post: 26th August 2013, 02:34 PM
  2. DK's progress thread
    By K.J. in forum Projects
    Last Post: 15th March 2009, 11:35 AM
