Results 1 to 7 of 7
    What people thinking about Ludespeed A2W kit?
    It's available on PP atm n I'm very interested, here's the link, curious what people think of it?
    what the seller has replied me:
    "yes. stock can hold up to 8lbs. the actaul setup is on a 5lb spring and is more than enough for a stock motor.
    if youre running the 5lb spring. minimum is a tunable ecu, guages that youd want, at least boost guage and wideband, a/f ratio. the injectors and map sensor will hold up until pass half a bar which is 7.35lb."
    wonder what's the power/torque with 5lb boost? any other parts I might need? besides the kit will another 1k budget be enough?
    5 psi on a small turbo and 5psi on a big turbo will return different power figures, so it's hard to say. 5 psi with a small turbo should easily give you a 50% increase at the wheels.
    you will need:
    tunable ecu
    bigger injectors, yes, even on 5psi
    a tune
    wide-band o2
    the 4 items above will cost you 1500+ unless you get a good deal somewhere
    now my views on water 2 air intercoolers
    I used to be a big fan of water to air kits, but after much research i found that poorly setup a2a will outperform a poorly setup w2a. I looked at the ludespeed kits back when Tom was still making them 10 or 12 years ago, and also checked them out again a couple of years ago after i first went turbo. In my opinion they aren't the best, they use a modified air 2 air intercooler core, which really isn't the best way to go, there are also too many sharp direction changes in the design. Some of the later ones he made were modified mass produced w2a cores which would have been a little better.
    Some will say you get too much lag from an a2a system, but i didn't even notice a difference going from a straight pipe to having the intercooler, it's all in the pipe size selection.
    Other drawbacks with w2a is the slow response time, if you've been park your car and come back 5 minutes later, the system will be heatsoaked and willl take a few miuntes for the temp to stabilize lower. With an a2a, you will still heatsoak, but the temp drops almost instantly.
    w2a has fans and pumps that draw power from your electrical system, if something stops working you'll loose cooling.
    a2a worst that can happen is a hose might pop off, or you might get a rock damage your core. Same problems exist with w2a.
    well said ^^ ^^
    1,047
    you will need:
    tunable ecu
    a tune
    wide-band o2
    that being said though Ian, would you still feel the lag with a smaller turbo anyway?
    ʍǝɹɔ uʍop ǝpısdn
    私の進行中のスレッドを確認してください
    Nov 2010
    1,211
    smaller turbos have less lag don't they? So they have a more linear pull and less of a 'TARBO JUST KICKED IN YO' feel
    correct, small turbos have less lag, but they can still kick hard
    ball bearing turbo's on the other hand are very linear, you still feel it coming on, but it's not so harsh
    only pic I can find:
    belongs to B20luda on PP
    From I read so far this setup is for people who want a sleeper look n night kid who loves drag racing in the night
  1. just thinking...
    By skinnyboy in forum Chit-Chat
    Last Post: 20th May 2009, 02:29 PM
  2. Sup people'z of PA
    By CJ'S_HONDA_PRELUDE_"90" in forum Introductions
    Last Post: 15th February 2007, 02:54 PM
  3. Sh People
    By Too_Funny in forum Fifth Generation
    Last Post: 9th November 2002, 08:13 AM
