Page 2 of 16 FirstFirst 123412 ... LastLast
Results 16 to 30 of 233
    Vtir
    Mar 2009
    443
    ok small update hopefully will have it finished by the end of today =]
    more work on the gauges with the proper material this time
    im planning on working the whole dash this way
    and the rest of the pod
    the material is just like recaro seat material alcantara, so yes these will match my seats =]
    ill be working on the base today.
    ive also got some pvc pipe to start the header mock up so ill post up what i come up with later.
    Sep 2010
    976
    Awesome work, keep it up!
    Vtir
    Mar 2009
    443
    ok small update on what ive been up to
    my sister got a little further with the sewing i happy with it it looks awesome =]
    and i pulled out the pvc piping and had a look at what would fit and work just a rough mock up, i didnt puller the headers off to get a real judgment of space but i held it just above where i wanted it mounted and it should work out fine, but ill see for sure when get into it properly
    anyways pics of what ive come up with so far, looks like ill be opting for the topmount after all.
    what im hoping to achieve with this configuration is that the tight squeeze of far 1st runner will hug the second runner straight down past its bend, then turn into the collector,
    the fourth runner will hug runner 3 except it wont diver under runner three but go over the top and into the collector hopefully leaving enough room for the dump pipe.
    if the actual pipe diameter turns out to be smaller than the 40mm pipe im using now it will be a bonus.
    hopefully ill put up the picture of the finished dash piece 2moro =]
    enjoy =]
    ill post up a picture on how the turbo should sit when i have an extra set of hands lol
    Vtir
    Mar 2009
    443
    thanks man ill keep them coming as fast as i can =]
    Jun 2010
    366
    yeah looks like qld is the state of boosted hondas... only place to be.
    we dont FU*K around up here MATE !!!!!! hehe
    Vtir
    Mar 2009
    443
    UPDATE!!
    ok i finished the manifold mockup, i just need to buy flange gaskets for the exhaust manifold so i can take it off and test it for fitment but im fairly certain there will be enough room for the dump and i should clear the front engine mount, since the two side runner will look like this
    and from the front
    ill have to double check this when i buy the mandrel bends but it looks like i might have to have a slight angle from the exhaust flange .
    yes i did measure the distances and centers i did not just write numbers on a piece of wood lol.
    from some quick measurements it looks like the manifold will be 27 cm deep roughly which should clear the cross member, and 17cm from the flange which should clear the radiator the shroud might need to changed, or ill move the fans around... not sure yet.
    the next step is to make the collector and now im having a bit of trouble, i might see if i can use autocad, and create it there so i can determine angles on which to cut pipes.
    Problem.... i cant use autocad lol
    I realy like the cluster your doing....
    And the mock up is coming along nice.... Here we go again.... Another boosted lude on the way.....
    Vtir
    Mar 2009
    443
    cheers mate =]
    that pod thing is almost done i just need to have the last pod stitched on and the holes cut in the dash piece. ill probably ask ian to relocate the gauge wires for me again lol since i my knowledge ends there haha.
    btw man the t28 flange did you buy that yourself and hand it to shops? haha or was it given to you =p
    It's so easy to buy one......
    Vtir
    Mar 2009
    443
    I know man, just wanna know if some are better than others. I found one for 60 but im not sure what steel it is.
    deciede if your going to use mild steel , steam pipe or stainless . ( steam pipe is the best choice as it will hold alot of weight when very VERY hot ) and get a flange of the same type .
    Vtir
    Mar 2009
    443
    I was thinking of using 312 stainless steel, i think its 312, 304 works i hear but 312 is preffered so im told.
    Ive never heard of steam pipe, how does it compare to 312?
    If not most important price? Lol
    Thanks for the help =]
    Regular Member pure_oxyg3n's Avatar
    439
    Most suppliers only stock either 304 or 316 when it comes to stainless steels I think man.
    id use steam pipe over anything else . my manifold is a custom steam pipe manifold . go see some fabricators and ask about steam pipe . im pretty sure ian has a steam pipe manifold aswell .
  1. Forbeszy's Progress Thread
    By forbeszy in forum 3rd gen
    Last Post: 4th May 2015, 09:11 PM
  2. My Progress thread
    By manolii in forum 5th Gen
    Last Post: 26th August 2013, 02:34 PM
  3. Benji's new progress thread
    By Benji in forum Projects
    Last Post: 31st July 2009, 10:19 PM
  4. DK's progress thread
    By K.J. in forum Projects
    Last Post: 15th March 2009, 11:35 AM
  5. Sp4rX Progress thread.
    By Sp4rX in forum 4th gen
    Last Post: 4th August 2008, 10:03 AM
