Results 1 to 4 of 4
    Feb 2012
    5 Speed Box Conversion
    Can someone plz help me as i dont know what i need to do the transplant.
    It is auto at the moment but no reverse.
    can u plz tell me what i need to do and parts i need as i bought another with a 5 speed box in it.
    thanks guys/girls
    The first thing you need to do is start your thread in the right area.....!
    This is not going to be an easy job for you.... But i'm sure some of the 3rd gen gurus will help you out...
    Regular Member Builds.the.Fire's Avatar
    178
    Parts Needed
    Pedal Assembly w/clutch pedal
    Manual Transmission
    Manual Transmission Starter
    Flywheel W/8 Bolts
    Throw-out Bearing
    Clutch alignment tool (TAT-5319)
    Transmission Mount For Manual
    Clutch Pressure Regulator
    Clutch W/ 6 Bolts
    Clutch Cover
    Clutch Master Cylinder
    Clutch Slave Cylinder
    Shifter Assembly
    Shift Linkage W/ Trans Bracket
    ( Cont Auto Cru) MT
    Brake sensor on pedal W/plug
    Clutch sensor On Pedal W/plug
    Box of Sandwich Bags for All Bolts and Small Parts
    & 2 ft of heater hose the orig hose is to short
    Oh and you will need three M10 X 1.50P X 90mm bolts for the trans mount. and one about half in shorter.
  1. help with fuse box
    By Sambalam in forum Fourth Generation
    Last Post: 18th November 2009, 10:57 PM
  2. manual g/box
    By Xgeneration in forum Fifth Generation
    Last Post: 24th November 2008, 05:00 PM
  3. 6 speed manual conversion
    By Stomp98 in forum Fifth Generation
    Last Post: 5th April 2007, 04:57 PM
  4. Relay Box
    By Detach in forum First / Second Generation
    Last Post: 2nd February 2005, 09:00 AM
  5. What Do You Guys Think The Best Box Is
    By killerprelude86 in forum I.C.E / Electronics / Security
    Last Post: 13th November 2002, 03:47 PM
