Results 1 to 10 of 10
Thread: Rough Idling
    Si VTEC
    Apr 2012
    157
    Rough Idling
    My 92 Lude when I start it up in the morning isnt smooth idle, it always is vibrating abit, I thought it be spark plugs but I changed them anyway but no difference, could it be any of this?
    I got a right hand side broken engine mount
    really bad worn shocks
    really bad worn front control arms
    excasut leak or could be my EBAY cat
    now some of these might not have anything to do with car not vibrating but thought id write it up
    Engine mount. And engines do vibrate. Are you getting any major vibration through the steering wheel?
    It could also be low idle, whats the rpm during warm up, and does the vibrating go away once its heated up?
    Si VTEC
    Apr 2012
    157
    so engine mount could be u reckon??
    nah idling rev is smooth it idles over 1100 when cold and u sit down and feel car vibrating but not alot just decent bit of vibration as i let it warm up it idles around 800/900rpm vibrating does drop abit after few minutes but not always
    Main symptom of busted engine mounts is vibration. That'd be it.
    Si VTEC
    Apr 2012
    157
    yeah thought so
    yeah sounds like the engine mount is your problem
    Si VTEC
    Apr 2012
    157
    I also had a excaust leak on my ebay extractors 4-2-1 and i got it welded but then it came back again in a different spot tho, I heard that a broken engine mount can also give you excaust leaks by engine not being properly secure
    Quote Originally Posted by H22JET View Post
    There is truth to that, but that could happen with any extractor as most of the exhaust is hung under the car and on the back of the engine. Even hitting it on speed bumps or bottoming out could do that. Think you need a new mount to save you from more problems. Could always repair the mount using sikeflex if its do-able, I have no idea cause I don't know the condition of the mount
    Si VTEC
    Apr 2012
    157
    yeah i agree 100% would you know roughly the cost of a single standard engine mount for a h22a sortof low on cash atm
    No idea dude, I'd try ebay just cause its convenient, then theres the forum someone may have a spare they can part with, then there are wrecking yards but they can be a bit tricky, and expensive.
    Then again if it is repairable a tube of sikeflex will only set you back $20 or something. But you'll be stuck without the mount for a few days while it drys
  1. Car shakes while idling after vtec
    By nounderscore in forum Fifth Generation
    Last Post: 20th August 2008, 08:47 AM
  2. Idling/Stalling Issues
    By DOH23aC in forum Fourth Generation
    Last Post: 29th September 2005, 01:41 PM
