Results 1 to 15 of 15
    Regular Member Hadamona's Avatar
    Dec 2002
    241
    Hadamona's SPL install
    This is what I've been busy working on. It's the biggest box I can go, it's only 80.5 litres after displacement even though 42.5 litres per sub is recommended. Port area is as big as possible (201sq.cm or 31.2sq.in) at 44Hz without being too close to rear wall or taking up too much volume. This isn't a build as such, just an experiment at this stage. I'll update with a video after it's installed.. As far as the equipment goes, I'm using two DC Audio XL M2 12" subs, two Vibe Black Death Bass 1 amps and a Fullriver HC65 AGM battery (will add another soon). Lets see how loud I can get this car Highest previous score was 134.8dB with 500wrms and one 12" sub. Now using two 12" subs on 5000wrms
    Track: White 1988 2.0Si 4WS Daily: Silver 1989 2.0Si 4WS
    Dec 2002
    241
    8ga speaker cables, 36mm baffle
    Anyone want to sit in the back?
    Running out of space
    I'd be upgrading the alternator as well . have seen 120-150 amp alternators on eBay .
    Wouldnt a sealed box improve it? As anything that is ported generally requires a greater volume inside the box to perform as well?
    That fit's in better than a bought one. Damned fine work.
    IIRC Ported is better if you are tuning to certain frequencies. Will give higher SPL numbers. Where as sealed gives a tighter response across a more broad frequency range.
    Xzibit would be proud
    Correct - if you get a properly tuned box with the correct volume, or a adjustable port. If space is an issue then a closed box can give you an edge however as it requires less space and easier to "tune" I believe as it allows for greater variance. Porting requires a more specific build to et the best performance.
    Got to admit the fit of that box is pretty impressive. Will be stealing those measurements as might be required for myself.
    Dec 2002
    241
    Still needs some isolating off from the boot, and i'm still running a single bat (Fullriver HC65) and stock alt (90A) so burps are dropping voltage to around 11v (bad I know).. But these Vibe Black Death Bass 1's sound fan-f***ing-tastic!, Class GH ftw so so so clean! I'm thinking of building another box, currently the tuning is way too high which I knew before I built this one but I was desperate. I just didn't want to mess around with current false floor and batt mounting, plus I could still access the spare tyre.
    There goes the neighbourhood.
    They certainly get moving.
    nice work .
    PA Resident brash's Avatar
    4,177
    Done well mate. Have you run a number yet?
    Dec 2002
    241
    Attending a soundoff tomorrow arvo at Harrys Diner, should have some numbers after then
    Upgraded to two Fullriver HC65 batts.. rear suspension has dropped at least an inch after installing 120+kg of gear
    I couldnt find this thread. Needed to plan with those measurements. Thanks for the progress.
    Jan 2010
    384
    what program is that you used to design the box man? will be designing a boot install for m car over the uni holidays and this looks good!
    Cheers.
    Quote Originally Posted by chimera92 View Post
    Cheers.
    Looks like bassbox software
  1. Hadamona's 3G track car progress
    By Hadamona in forum 3rd gen
    Last Post: 10th October 2011, 12:12 PM
  2. Hadamona's 3g
    Last Post: 8th July 2008, 02:15 PM
  3. Can I install myself..?
    By Mike11 in forum Fifth Generation
    Last Post: 20th May 2005, 07:49 AM
  4. Tv Install
    By primerlude4ws in forum I.C.E / Electronics / Security
    Last Post: 6th January 2003, 08:01 AM
