Results 1 to 10 of 10
    Regular Member Prelure's Avatar
    242
    Manual Gearbox Clunking when putting gear in and changing gears,stand still + driving
    Hi guys,
    My 5th gen is making a clunking noise when im in neutral and putting it in gear and when driving it clunkes each time i change gear.
    What can this be ?
    Regular Member manolii's Avatar
    ATTS
    348
    have u changed the fluid?
    Could be an engine mount.
    Junior Member ddoth's Avatar
    Jul 2011
    9
    It wouldn't be your clutch going out would it ?
    PA Resident Flipmods's Avatar
    3,513
    Tighten your wheel nuts?
    BRING BACK THE FORUMS!
    Junior Member mediasorcerer's Avatar
    Jan 2012
    46
    bleed the clutch, not hard to do, there is a nipple on the slave cylinder i believe, you can reco the master yourself if you handy with a spanner or buy a gasket kit and new slave,thats where id start,
    Sep 2009
    92
    I just had an issue with my clutch losing copious amounts of fluid. I replaced my master cylinder, and after adjusting the actuator travel my car drives better than ever. I did the accelerator too while I was there and can't recommend it enough. My pedals have no play at all now, and my every day crunching (even reverse) is a thing of the past.
    Honda Pride!
    Jan 2012
    46
    Yep i need to do mine too, slight shudder in first, but the clutch is strong, bet its the slave and/or master.
    Feb 2012
    239
    it'd most likely be driveshaft, engine mount or the gearbox itself.
    When inner axles go they can make an annoying clunk with any movement to the drivetrain, accelerating/deaccelerating, changing gear etc.
    seeing as its doing it on the spot that probably cancels out any suspension issues.
    Jan 2012
    46
    Oh yeh i just replaced a clunking driveshaft on my bros hyundai , your right!! His was making clunking noise when you turned the wheels to the right etc.
  1. Jerking while changing gear
    By DRK291 in forum Fourth Generation
    Last Post: 12th August 2008, 11:28 PM
  2. car blowing smoke when changing gears
    By lude93 in forum Fourth Generation
    Last Post: 22nd October 2007, 11:23 PM
  3. Changing gear knob on auto
    By gunit in forum Fifth Generation
    Last Post: 10th August 2007, 01:02 AM
