Results 1 to 15 of 26
    254
    Rydah's progress thread
    so i thought id make one of these instead of bothering you guys with lots of small threads, anyhhooo.
    planning to turbo my lude, but for now only have it at 7psi till i upgrade my internals, my car is my daily so unfortunatly i have to do everything backwards which will take alot longer but meh, i got time.
    so the plan
    7 psi external wastegate
    simple turbo manifold
    2.5 inch downpipe back
    2.5 - 4" 100 cpi cat
    2.5" x 15" hot dog
    2.5" inlet 3.5" outlet cannon (RICE)
    To4E turbo with 5 bolt pattern (not v clamp)
    300x300x76mm intercooler 3" piping
    oil lines
    boost gauge (hidden behind tweeter covers)
    thats it so far, just a simple turbo set up, nothing big......for now
    sounds good, you'll need some sort of ecu and bigger injectors too.
    254
    yeah?
    what would you recommend? nothing too extreme i hope
    I recommend one of the tuning solutions based on honda ecus, Hondata, Neptune, Crome Pro, ECtune.
    ECU + tune will set you back $1000 - $1500
    injectors will set you back around $250 for a set
    254
    what size injectors would best suite?
    Somewhere aroung the 500-600cc region would be fine.
    254
    today i got my exhaust metal and rear bumper (stock)
    i got 6 metres( case i fck it up)
    2.5" 406 mild steel 1.6mm thick
    1,143
    Get 2.5" intercooler piping. Not 3". And injectors ull only need like 450cc.
    You're going to need some mandrel bends.
    Also, before bothering with the exhaust/dump pipe, you need to mock up your turbo and manifold so you can get the positioning.
    254
    yeah, ive mocked it up. need to move the rad or get some kind of smaller one if thats possible, like a really thick civic one
    edit: what thickness should i make the new radiator if its half the length?
    edit: edit:
    was thinking this
    http://www.ebay.com.au/itm/42mm-Hond...ht_1237wt_1163
    http://www.ebay.com.au/itm/High-per-...#ht_786wt_1163
    1,143
    U shouldnt have to change ur radiator to a half sized one. But yes a thicker full size one would be better.
    ^^^ +1
    Get a 56mm aliuminium Koyo or similar. You can still fit a decent manifold down there.
    I'll stop short of saying you'll fit it down there easy. But you'll fit it....
    254
    ^^^ +1
    what shroud? and thermos?
    1,143
    Thinnest ones u can find. Try get a radiator that comes with some.
    254
    Quote Originally Posted by Phatlude View Post
    as to what pacman said, koyo or simmilar? am i to avoid any particular brand?
  1. SAKI's Progress Thread
    By SAKI in forum 3rd gen
    Last Post: 5th July 2010, 03:23 PM
  2. DK's progress thread
    By K.J. in forum Projects
    Last Post: 15th March 2009, 11:35 AM
  3. 94_Lude_Dan's Progress Thread
    By 94_Lude_Dan in forum Projects
    Last Post: 1st July 2008, 07:10 PM
  4. Psycodeliks progress thread
    By psycodelik in forum 3rd gen
    Last Post: 11th April 2008, 10:30 AM
