Results 1 to 9 of 9
    254
    Wink most ideal manifold
    what have you 4th gen-ners found to be the best exhaust manifold, not for quality but for positioning the turbo in the ideal spot?
    a custom made manifold is prob the best as you can get the turbo fab'd to which ever position you desire . down side very expensive
    254
    i was only after an ebay manifold, one that can hold 12 psi maximum, im not going for high boost, id only ever sit around 8 psi
    1,143
    The low mount manifolds u find on ebay dont fit with a big turbo cause the turbo hits the front engine bracket. The only cheap ones that work ok r the short ones that sit the turbo right infront of them. But the 2 middle runners are way shorter than the outer 2.
    254
    Quote Originally Posted by Phatlude View Post
    ive seen them, is that bad? i know it would have some effect, but anything to worry about?
    1,143
    Well it means that 2 cylinders work harder than the others. Personally. If ur not wanting big power or anything then it will be fine. But later id prob upgrade to a better one.
    254
    sounds like a good idea, like once ive finished prepping my other block to put in get fabbed ones.
    thanks guys
    also what do you reckon is ideal boost to run on a stock motor? i was thinking 5psi, (itll be on an external wastegate) i also have a 8 pound 10,12 pound springs
    1,143
    Nothing over 7psi
    254
    Nothing over 7psi
    thanks man
    you know of anyone selling stock front bumper? 4th gen bonnet, and climate control shit?
  1. Ideal RPM Shift
    By unicorn6571 in forum Track / Drag Racing
    Last Post: 13th August 2007, 01:07 AM
  2. ideal NA setup??
    By unicorn6571 in forum Third Generation
    Last Post: 31st May 2007, 02:18 PM
  3. The Ideal Na H22a Setup
    By JDMet2 in forum General Prelude Discussion
    Last Post: 16th October 2002, 08:06 AM
