    Senior Member RedLineResident's Avatar
    Nov 2007
    860
    King Springs Catalogue says "Excluding VTEC and VTiR" - anyone know why...?
    Hey guys,
    I'm looking to buy a set of springs asap as the one's I've fitted give a mad drop, but not one I can live with.
    I want to get a set of springs that lower the car but without tucking too much of the tire this time, and Kings come to mind 1st.
    However upon going to a store to order a set I get told that the listing is for a 97-01 prelude but does not support VTEC or VTiR preludes...
    Such as per this link - http://www.wholesalesuspension.com.a..._catalogue.pdf
    Bottom of page 10.
    Is this a misprint?
    How many have bought from Kings, was this ever an issue, and what sort of drop will I be looking at?
    Thanks
    My Mind Not Only Wanders,
    It Sometimes Leaves Completelly
    11,093
    I'd suggest it's an error.
    I'm not aware that here is any difference specifically for the Vtec.
    The springs should fit and work fine.
    Nov 2007
    860
    Cheers mate
    I think they've got it mixed up with the ATTS model.
    I had a similar issue with the 4th gen being told there was no springs for a vtec 4th gen, so i got the 'si' ones and they fitted fine so i assume its wrong.
    11,093
    The only difference on the ATTS is the extra 2 bolts on the strut tops. This has no impact on the springs. I have no idea why they would have written this into the catalog.
    VTiR ATTS
    572
    Extra bolts is JDM. ATTS has a slightly different front suspension setup. As I understand it, you can use regular springs, but you need matching shocks. If you are running ATTS front shocks, then you would need matching ATTS springs.
