Page 1 of 5 123 ... LastLast
Results 1 to 15 of 68
    Jun 2010
    366
    GT35R Setup On Prelude
    Hey Fellas/Girls
    Was just wondering if anyone has had any experience with the gt35r turbo setup on their prelude? I'm wanting to go down this path as it seems that it puts out reasonable horsepower for street use and will be something worth the money and time. Now the other question is if people think this turbo is suited to a near stock h22a or would their need be some internal work done? Is their any pacific places people know where to buy h22a turbo parts to work with a gt35r?
    as much information i could gain will be appreciated.. thanks
    Senior Member Nonricerprelude's Avatar
    Leather
    Nov 2009
    633
    well im planning on using a GT28RS on my car and im swapping out internals.
    but my engine is a B20A5
    3RD GEN LUDER--------------------
    Ricing It Up alil'
    Jun 2010
    366
    so you'd think internal work might be needed to run a gt35r? the basic setups i've seen is basically is to run a fmic, gt35r, bov, and the normal setup.. and maybe run low boost until some other mods have been made?
    Leather
    Nov 2009
    633
    well yer u can run around 7psi without internal work but as advised by other members above 7psi can result in damage.
    edit: im swapping internals cause i want to push 16- 18psi max.
    Ricing It Up alil'
    Jun 2010
    366
    yeah true that, so what internal gear would you reckon is the best option to say run 15psi safely?
    edit: oh fair enough.. i would be happy to run 15 - 18psi of the gt35r.. as its rated between 300-500hp with the right mods. so wouldnt mind to get 200kw outa the h22a.. and if that means upgrading some internals then thats what im asking is the best way to head?
    Leather
    Nov 2009
    633
    im not exactly fimiliar with h22's but bearings, MLS head gasket, pistons and rods from the top of my head.
    you might need a higher flow fuel pump and injectors. im sure phattzy, bob or members will correct me if im wrong
    Ricing It Up alil'
    to run 15psi max i would be looking at new ecu ( hondata s300 or other's like adaptronics e420c that im using , motec , link , haltech etc etc ) acl and king bearing on the crank and rods , scatt h22a h-beam forged rods , forged piston's with a static 8.5:1 C/R with a good set of chrome rings , cometic mls head gasket , decked block and a cyclinder hone as well as a deck on the head aswell , larger injectors between 500cc-800cc , over sized fuel rail from AEM , in-tank walbro 255lph fuel pump , rise rate adjustable fuel pressure regulator , external waste gate nothing smaller than a 40mm , boost controller , bov , hope im not scaring you but i bent stock rods on 10psi in my b20 , now its fully forged decked prepped and ready for 30psi of glory . good luck dude and if you have any queastion send me a P.M and id be happy to help another couple of people to talk to is bob , pfj lude and adrenilan .
    Jun 2010
    366
    ohh i see, so in total for the new ecu, injectors, forged rods etc.. how much would it cost? and is any of these parts definitely needed to run 15psi? or just to be on the safe side of the engine blowing? at the moment.. im trying to get rough ideas on parts and price figures as i dont know any good websites for cheap parts etc.. any help in that department also would be great!
    Leather
    Nov 2009
    633
    well ive researched for myself and found the parts alone for me is around 5k -8k. but im still looking and changing my mind
    Ricing It Up alil'
    A GT35R is a pretty large turbo for the H22 and capable of a fair amount of power.
    If you are set on this then I'd guesstimate $10-15k to get a reasonably reliable system.
    It will be laggy though. If it's power you want it costs money.
    If you are looking for something a bit more streetable I'd be looking for a GT28. Sub 7-8 psi will net a nice cost effective system. There is still more potential but would require internal upgrades.
    off the top of my head so dont quote me
    rods $500
    bearings $300
    pistons $1200 includes ring set
    hone and deck $200
    mls head gasket $100-$150
    fuel rail ?
    FPR $ 150
    W/G $ $300-$600
    turbo $1500-$2500
    injectors $350-$500
    pump $100-$150
    ecu ?
    tune ?
    if manual new clutch to handle the extra power and are you doing this or going to pay someone to build it for you ? labour will kill you and after you spend close on $20000 in labour and part its cheaper to buy someone else hard work . ive done 99% of the work on my lude and engine alone $15000 !!!!!! a gt35r on a h22a is a very expensive way to boost a h22 , id be more incline to go bobs way and a gt28 . less work , less parts to buy , more money to put in the fuel tank to enjoy . lots of lag from that turbo aswell with a stock head , i have exstensive port/polish work on my head $2500 worth to be precise . and i still have lag but no where near as much as a gt35r on a stock h22 head . id sit down and really think what the car will be used for mainly and build it to that dude .
    Senior Member DrTony's Avatar
    Apr 2007
    758
    so expensive...... O.o lol
    It's Tony!
    Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
    Jun 2010
    366
    rods $500
    bearings $300
    hone and deck $200
    fuel rail ?
    FPR $ 150
    W/G $ $300-$600
    turbo $1500-$2500
    injectors $350-$500
    pump $100-$150
    ecu ?
    tune ?
    ohh i certainly see.. yeah and hopefully labour will be done by myself and a mate who knows what his doing.. and would you reckon a T03 or a T28 is a better path for the mean time and set myself up.. then possibly if i wanted more horsepower i could just upgrade the turbo and internals? might work out a bit cheaper just to get a basic turbo setup for fun.. then maybe more serious power if i want more.
    Jun 2010
    366
    would love for the end result to be something like this.. except more of a dose/flutter instead
    http://www.youtube.com/watch?v=M-zprRyKMOA
    Jun 2010
    366
    ohh and another things.. would a turbonetics gtk350 i think its called which your using phattzy be alright on 7psi on a stock block h22a? or is it still too much like the gt35r and not the gt28?
  1. The Honda Prelude Improvemment Project
    By TYPE SH Prelude in forum Projects
    Last Post: 12th March 2009, 10:28 PM
  2. Prelude Joy!
    By Terry_GT-R34 in forum Introductions
    Last Post: 11th September 2008, 10:53 AM
  3. 89 prelude Si setup.....
    By Silverfist in forum Third Generation
    Last Post: 4th January 2005, 02:43 AM
