Results 1 to 7 of 7
    Regular Member Hengist's Avatar
    Sep 2007
    United Kingdom
    185
    OEM Fog light switch wiring?
    Anybody got any idea what the 5 wires coming from the OEM foglight switch do? I can't seem to find any relevant wiring diagrams on the web.
    I've an aftermarket fog wiring kit in, which only has 3 wires - live switched, earth and switch illumination, with a crappy little light-up rocker switch.
    Any clues as to how to wire up the OEM switch to these 3 wires would be hugely appreciated!
    (Gen 4 switch - could be UKDM or JDM, not sure now - had it lying about in the garage for ages).
    Angus
    JDM fanatic !JonZap!'s Avatar
    Flying Broomstick
    2,686
    The oem 4g foglight switch only uses 3 wires (exactly the same as your aftermarket one), I would check for you and tell you the pinouts but i don't have a switch close by. Which switch have you got? 92-93 or 94-96?
    Imitation is the best form of flattery
    Sep 2007
    United Kingdom
    185
    Cheers - I have two switches, both from 4th Gen cars but not sure what years (took them out myself at the scrappy). I intend to use them for my front and rear fogs.
    One has 3 wires, the other has 5. I snipped the wires rather than just unplugging the switches, so I could patch them into my existing ones.
    If you could find the pinouts from the switch that'd be great, though I've no idea why one of them has 5 wires going into it. I'll check the wire colours when it's not dark out in the garage!
    Angus
    Junior Member Platinummale's Avatar
    JDM Si VTEC
    Mar 2012
    46
    BB4 centre console fog light switch
    I have just bought my 94 lude and have noticed there are front fog lights but I cannot for the life of me find the switch to in anywhere in the car. I guess my first step is to buy/find the switch and then second step is to find the wiring for this .
    I have been searching high and low all over the place to find a front fog light button/switch for my 94 prelude (but with sexblocker centre console) that will fit in to the centre console (there are 4 empty slots there).
    Can someone point me in the right direction or have one for sale? also will the bb6 switches fit??
    I don't think the 5th gen switches fit. Ebay the switch, shouldn't be too hard to just go for an aftermarket switch. The wiring should all be there you just need to plug in the fog lights and plug in the switch.
    1,048
    YAY RT is back!
    ʍǝɹɔ uʍop ǝpısdn
    私の進行中のスレッドを確認してください
    PA Moderator iluvmylude's Avatar
    Apr 2005
    340
    Quote Originally Posted by renzokukenj View Post
    YAY RT is back!
    Thanks for the heads up and thanks LB
  1. OEM fog lights
    By hprelude in forum Fifth Generation
    Last Post: 22nd February 2010, 07:51 PM
  2. Fog light installation
    By krnjoejoe in forum Fifth Generation
    Last Post: 21st September 2008, 05:56 PM
  3. JDM Foglight Switch wiring
    By Dicko in forum Third Generation
    Last Post: 25th August 2006, 05:02 PM
