    Jun 2010
    12
    need help/advice
    my lude is making a knocking sound when i change gears, i dont think its anything to do with the gearbox itself, im pretty sure its to do with the momentum, as it doesnt make a noise when i change from forth to fifth(being a smooth shift). First to second is the loudest knock... it comes from roughly the middle of the car, under the rear seats, any thoughts on what it could be or if this has happened to anybody else.. just wondering on a fix and the cost.
    cheers for any help.
    372
    engine mounts maybe? gearbox mounts?
    Jul 2010
    13
    Probably unrelated but my prelude was making a knocking sound in the rear when going over bumps. I got a wheel alignment and the notes said something like "backing plate hitting handbrake cable".
    Doesn't make the clink sound anymore.
    Junior Member thatblackprelude's Avatar
    Jan 2010
    13
    i think its the engine mounts i had the some problem as well, does it happen when you reverse from stationary?
    Jun 2010
    12
    yeah, a friend agrees with the engine mounts idea,, any i dea how to test this theory or is it just replace them and hope, also can i change them myself??
    Dec 2009
    183
    Look at them to see if they are broken?
    They are quite hard to get to, and unless you know what youre doing id go to a mechanic.
  1. Need help/Advice
    By peejayy in forum Fifth Generation
    Last Post: 20th June 2007, 11:17 AM
  2. new engine but no header!?.. need help/advice!
    By draconx in forum Fourth Generation
    Last Post: 22nd April 2005, 11:19 PM
