Page 2 of 21 FirstFirst 123412 ... LastLast
Results 16 to 30 of 314
Thread: Nonricer...
    Gold Member gumus89's Avatar
    Jan 2008
    2,321
    So its a chinese product?
    Is the quality fine?
    <a href=http://www.preludeaustralia.com/forum/showthread.php?t=42730 target=_blank>http://www.preludeaustralia.com/foru...ad.php?t=42730</a>
    Back to it's former glory... Almost.
    Senior Member Nonricerprelude's Avatar
    Leather
    Nov 2009
    633
    yes its surprisingly good only problem i can pic is the digital tv antena (havent had time to truly test it) is ok but could be better.
    3RD GEN LUDER--------------------
    Ricing It Up alil'
    Leather
    Nov 2009
    633
    small sony amp is installed.
    i used some spare wire i had in the shed, so no expensive transparent Sony Wire.
    i threaded wire not through firewall but through front driverside fender, its way easier.
    had to remove plastic wheel arc cover, found awhole lot of dirt.
    i now need to clean out whatevers on the otherside.
    covered all exposed wire with (i call it centipede skin) split tube.
    all works perfectly..
    Ricing It Up alil'
    Regular Member Hadamona's Avatar
    Dec 2002
    241
    Nice tidy amp install, what speakers is it running?
    I'm surprised you found it easier to remove all that plastic under the wheel arch rather than find a hole in the firewall.. kudos to you! I'm lucky I have an auto and the clutch line grommet is perfect size for cable
    I can relate to the dirt buildup behind the mud guards, I managed to scoop out half a bucket of dirt out of each side!
    Leather
    Nov 2009
    633
    cheers hadamona, its running two sony xplod 6x9's and two 6" Kenwood i got from sprintauto's.(cheap replacment)
    just got to get a "real" amp so i can put the Sony Subwoofer in. but this small one is powerful enough for now so not in a hurry.
    Ricing It Up alil'
    Leather
    Nov 2009
    633
    Picked Up alil Something from my now new auto parts finder and distributor
    Ricing It Up alil'
    Senior Member Baz's Avatar
    Aug 2009
    790
    i take it you're doing a DIY projector retrofit somehow? should be awesome if you can pull it off
    Leather
    Nov 2009
    633
    i am and i shall pull it off
    Ricing It Up alil'
    Jan 2010
    39
    will llok good when its done plenty o pics tho hey?
    Leather
    Nov 2009
    633
    ive started planing my attack
    better pics
    Ricing It Up alil'
    Leather
    Nov 2009
    633
    got myself a small early xmas present
    Ricing It Up alil'
    Regular Member foaley's Avatar
    Mar 2009
    430
    that will come in handy man. Ive been meaning to look into one. how much did it set you back?
    Leather
    Nov 2009
    633
    the dremel, i got from bunnings for $130 which is cheap.
    swaybar, got from local pedders store since pedders is a distributor for whiteline (handy info ther) for around $204
    Ricing It Up alil'
    Leather
    Nov 2009
    633
    it will be painted matt black
    Ricing It Up alil'
    Looking forward to seeing how these turn out
