Page 22 of 22 FirstFirst ... 12202122
Results 316 to 325 of 325
  1. #316
    Silver Member Seismic's Avatar
    Custom
    Jun 2004
    1,350
    Haha yes Elee! Build is pretty much complete. Just finished bedding the slugs into the sleeves and will have a final tune soon but ... the bluetop lives!!!
    The path of Honda is beset on all sides by the iniquities of Mazda and the tyranny of Nissan. Blessed is the Honda owner who in the name of handling and performance shepherds his Honda through the valley of darkness, for he is truly his Honda's keeper and the finder of lost kilowatts. And I will strike down upon thee with great acceleration and furious VTEC those who attempt to overtake and destroy my Hondas. And you will know my name is PRELUDE when I lay my VTEC upon thee.
  2. #317
    Gold Member WEAPON-R's Avatar
    2,319
    awesome to see you still at it!! man do i miss mine and the cruises AND the crew!! still hanging to see what it puts down on the dyno!!!!
    STUFF FOR SALE!
    4G jdm fog lights $80
    Had a prang? Front and Rear bumpers $50 each!!
    TANABE rear muffler brand new in box $250
    Thinking of going K series in your 4th gen?? I have the HASPORT BBK mount kit brand new for $400
    H22 intake manifold $50
    Brand new 65mm K series Throttle Body $100
    PM me for details!
  3. #318
    Custom
    Jun 2004
    1,350
    I didn't realise how much I missed mine until I got it back! I had completely forgotten what it was like to live without the constant stress of "must fix this", "must upgrade that", "must buy those"!
    On another note, I purged the cooling system last night. There really wasn't a lot of air in there. Drove it to work this morning and with all the additional waiting at traffic lights due to school going back it was giving me the CEL again by the time I was reversing into my parking spot. I wasn't data logging so I don't have a great amount of detail but I'm pretty sure my issue persists. I'll check the coolant again before I drive home but I'm not expecting any loss. Any ideas?
    Brand new radiator, custom SS coolant pipework, head only has 1100 kms on it since being completely stripped and worked so I highly doubt it's a blockage.
    The only thing I can think of is that idle the oil pressure is low enough to trigger the warning light. I have a suspicion that is due to the thin running-in oil. Pressure is perfectly fine above 1000 rpm. But any additional heat caused by low oil pressure should affect both ect sensors shouldn't it?
  4. #319
    11,093
    You really need to know what the CEL code is. Data log time.
    Steve (Adrenalin) was also having cooling issues, but seemed more related to air flow and the fans.
  5. #320
    Custom
    Jun 2004
    1,350
    Yes, agreed. Will do that over the next week but I'm pretty sure it's going to be an overheat reported by the ect sensor. One thing I've noticed is that the thermofans do not come on after shutdown. They only seem to operate while the ignition is on. From memory the Fan B sensor should switch them on even with no key in the ignition if the temps warrant, is that right?
  6. #321
    2,319
    by purging did you check the bleed valve after filling radiator, turning car on, letting it heat up till the fans come on and then bleeding from the lil valve that's somewhere i cant remember?? lol
    STUFF FOR SALE!
    PM me for details!
  7. #322
    Custom
    Jun 2004
    1,350
    Yes, I attached a clear poly pipe to the bleed nipple in the thermostat housing and dropped the other end into the overflow tank, opened the heater tap, cracked the bleed valve open two turns, removed rad cap and topped it up watching for bubbles in the clear pipe, got no bubbles just a steady flow of coolant, tightened valve, ran car for 3 minutes (not easy as it runs very rough when cold with the forgies), topped up rad and replaced cap. Sound right?
  8. #323
    2,319
    sounds right! and yes i know what youre talking about with forgies noisey and rough as on cold start..
    STUFF FOR SALE!
    PM me for details!
  9. #324
    Custom
    Jun 2004
    1,350
    Absolutely!! Hard to keep the coolant in the radiator when the cold engine is shaking it all out. And the neighbours love it when I leave at 4am
  10. #325
    How's things going with this Shane?
  1. TurboLude's Build Thread.
    By TurboLude_on19 in forum Showroom
    Last Post: 19th February 2010, 10:19 AM
