Results 1 to 13 of 13
    29
    Where does this vacuum line go? H22a
    Hi guys,
    here is a picture of a solenoid mounted inbetween the rocker cover and inlet manifold of my gen4 vtir.
    A vacuum line comes out of the inlet manifold, goes into the solenoid and out to the FPR.
    Although there is one port left open in my case.
    Where does the vacuum line come from for this port of the solenoid?
    Thanks!
    If that is the FPR (fuel Pressure Regulator) It should have a vacuum hose going back to the intake plenum.
    29
    As i stated, im talking about the solenoid pictured...
    Silver Member Veilside's Avatar
    Jan 2007
    1,348
    Thats feeds the quantum warp transfibulator! ee gads man!
    +1 it's stiffness that counts. Not Diameter. At least thats what the wife tells me.
    (not sure she knows that much about cars though)
    29
    come on guys...
    this isnt the most techanical of questions....
    can someone with a gen4 vtir please look under their bonnet. Would be of great assistance.
    Regular Member Hengist's Avatar
    Sep 2007
    United Kingdom
    185
    Mine's got a thing like that, but it's not bolted onto anything like yours is - ogften thought about finding out where it should bolt on, but always forgot. So thanks for that pic!
    For info, mine has a little round black cap thing on that tube, about 2cm diameter and 1cm high.
    Angus
    Senior Member TonyD's Avatar
    2.0 Si
    Apr 2008
    566
    Yeah I had a look at my mates VTiR, and it has a vacuum plug on it. Just go pull a vacuum plug from a car at the wreckers or something and put it on.
    also in the bottom right hand corner your pipe is cracked and needs replacing
    29
    Angus
    Thank you Angus!! Im assuming from what yoú've written, the solenoid is supposed to have a vacuum cap over it, ... a blocker.
    Which would make complete sense, since i cant find another open port for a vacuum line to go to.
    Thanks for your help
    Sep 2007
    United Kingdom
    185
    No drama, mate. Seems to be confirmed by what the other guys said, too. Thanks for your help, as well!
    Angus
    TYPE SH Prelude
    That looks like an electric switch that turns off or on some type of vacuum operated device . One hose supplies vacuum to the switch and the other hose should run to some vacuum operated device . Something that the ECU needs to turn on and of is not working . I would keep looking .
    Note : Did someone remove the sophisticated , stock , 2 speed intake pipping with its vacuum operated actuator and replace it with a low tech , aftermarket intake . That might explain why you can't find the vacuum device that you are trying to connect to .
    Junior Member Benno's Avatar
    Jun 2007
    74
    As much as I hate to say it, I think Robert has a point...
    29
    Quote Originally Posted by TYPE SH Prelude View Post
    Its called a soleniod.
    problem has been solved thank you.
  1. Free H22A Mods, worth it?
    By CUL8R in forum Write-Ups
    Last Post: 29th January 2014, 06:23 AM
  2. short question about ITB setup
    By K.J. in forum General Automotive Discussion
    Last Post: 31st March 2009, 07:32 PM
  3. AutoEngineer - 5th Gen Prelude Article
    By Menthu Rae in forum Fifth Generation
    Last Post: 29th September 2006, 10:08 AM
  4. H22A4 to JDM H22A Swap Notes v2
    By gerhard in forum Write-Ups
    Last Post: 11th August 2005, 03:53 AM
