Results 1 to 8 of 8
    Regular Member slcmorro's Avatar
    Jan 2009
    160
    Clay's Progress Thread!
    Ok. So, here's my 1992 Si with the F22B.
    It's got:
    Stainless Steel Extractors
    Home made Cold Air Intake with Pod Filter
    Autotechnica Cannon (crappy)
    So... this is the progress thread. I've got a list of stuff I wanna do. Some of this is easy, some of it is hard. Some's expensive, and some is relatively cheap. By all means, if you guys can think of a cheaper and easier way to do any of this, I'm listening all ears!
    Anyways, I'll cross things out during the year as I go. My plan is to have ALL of this done by 25/01/10, so it's started as of today!
    Fit MP3 Headunit (Sony Xplod 50Wx4 already in shed)
    Buy and Fit 6" Speakers for parcel shelf and doors.
    Buy and fit splits to suit, in dash setup.
    Check Amp connections and tweak/modify if necessary (there is an amp in it, havent had a look at it yet)
    Retint Windows
    Steering Wheel Replacement (would love a nice looking leather JDM wheel, but my Si has cruise... not sure if there are changeovers, or what's involved...)
    Buy and fit new 16/17" wheels and tyres
    Replace headlight bulbs and adjust headlights
    Regrease or replace with neoprene, all suspension rubbers
    Change out engine oil and filter
    Replace all spark plug leads
    General Tune up
    Touchup bonnet, rear guard and general paint
    Respray same colour (R82P) properly at a reputable place
    Give car a good cut and polish, overall 100% detail
    Fit new tail lights (don't like the solid red wedges)
    Fit strut brace and swaybars
    Fix crack in centre console (small crack behind handbrake)
    Restick carpet to centre console reaching into backseat
    Mount front bumper more securely (it sits right, just want to firm it up)
    Install new parkers
    Replace sunroof lining or cover sunroof lining with cloth with gold stitched Honda logo
    Fix starting issue (see starting problems thread)
    Fit gold Honda badges
    Retap spoiler threads (little bit rusted, not grippy enough on screws) or coat threads of screws with teflon)
    Drain and replace transmission oil
    Replace all belts
    Replace all hoses (vaccuum, radiator, the works)
    Replace door seals and rubbers where necessary
    Fit remote central locking
    Fit remote starter kit
    Fit/fabricate automatic sunroof closer
    Regas aircon
    Install better, sexier exhaust
    Reweld cracked weld on exhaust manifold (minor crack in original weld)
    Digitalise tacho/speedo (how great would a digital tacho/speedo look to match the rest of the dash? Might be a big complicated project... don't you bastards steal the idea )
    Modify nostrils (would like to make them mesh grilled)
    Buy and fit slimline personalised plates
    Calibrate 4WS
    Wheel alignment and balance (will happen when wheels and tyres are fitted, obviously)
    Cancel out valve train noise (it's a little ticky)
    Buy new service manual and original 92Si manual
    Lower car and redo springs and shockers
    Find and install suitable lip kit for front and rear
    1992 Si F22B
    WTB: 4th Gen Bonnet PM me.
    Dec 2008
    73
    Looks like a great project man, best of luck
    Silver Member PeachExperiment's Avatar
    VTIR
    1,385
    Hello Clay,
    You have some great ideas there, and certainly looking at what you have done already, you got yourself a nice little ride. Good luck with it all.
    That said, Ive moved this thread into a more appropriate section on the forum. Not only will this help keep our site in order, but more people will get to see your work within this section of the forum.
    Thanks.
    Project Joan Rivers
    The Old Bitch Gets A Facelift
    Coming Soon!
    Jan 2009
    160
    Thanks Peach, sorry it wasn't in the right spot to begin with!
    I'll learn, eventually!
    Anyone got any ideas on the list of 47 things above?
    1992 Si F22B
    Jan 2009
    160
    Just a photo of my 4th Si and a mates 5th VTiR at Torquay 2 weeks ago
    1992 Si F22B
    Jan 2009
    160
    Updated thread!
    Green = Done
    1992 Si F22B
    Gold Member peejayy's Avatar
    nice picture and nice progress!
    I like that your getting to some of the maintanance/basic things before venturing off! This project definitely has potential.
    Jan 2009
    160
    Yeah well I figured I'd make the car run as best as possible first, get it reliable and sturdy, and then get onto the cosmetic/yummy kinda stuff.
    1992 Si F22B
  1. Replies: 1085
    Last Post: 14th October 2014, 07:46 PM
  2. KaRLos ProGRess Thread!
    By karlos in forum Projects
    Last Post: 23rd March 2010, 02:56 PM
  3. pure_oxyg3n progress thread
    By pure_oxyg3n in forum Projects
    Last Post: 11th September 2008, 12:02 AM
  4. fmx's progress thread.
    By fmx990 in forum Projects
    Last Post: 10th May 2008, 12:37 AM
