View Poll Results: What Gear
Voters
155. You may not vote on this poll
  • Gear 1 - multipick if you use either
    84 54.19%
  • Neutral - multipick if you use either
    78 50.32%
  • Reverse
    27 17.42%
  • Doesnt matter
    17 10.97%
Multiple Choice Poll.
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 80
    Silver Member Knickers's Avatar
    1,488
    Quote Originally Posted by NuZo View Post
    on a hill facing down = reverse
    on a hill facing up = first
    on level ground = neutral
    EG.... carparks = neutral
    Parking on the kerb = first or reverse depending on hill mebbe even neutral if its level
    Same. fintelboss I really get confused by your post, I dont think an engine can start back to front? It makes my head hurt.
    Silver Member Veilside's Avatar
    Jan 2007
    1,348
    i use blocks under all 4 wheels just incase aswell as leaving it in 15th xD
    first always, as said by euroz wheels go either way if the clutch is in, but won't move when its in gear without the accelerator.
    2,980
    reverse when car poiting down hill
    1st gear when the car is pointing up hill or on flat ground
    Regular Member fintelboss's Avatar
    Oct 2007
    220
    ill try to simplfy,
    if the hand brake is off, and the car is in 1st gear, and you push the car, the engine turns over in the same direction it would if it was running and you were just driving normaly, however, you need to push very hard. it is because you have to push so hard to move the car that people leave the car in gear when parked, so if the hand brake fails the car wont roll away.
    now if you park on an uphill steep slope, in first, and the handbrake fails, the car will try to roll backwards, trying to make the engine turn over running in the opposite direction it was built to.
    now, i dont know for sure if this is bad for then engine or not, but i suggest it is, so recommend, contrary to other people,
    car pointing down hill = first,
    car pointing up hill = reverse.
    it may well be that there is nothing wrong with an engine turning over backwards, in which case the gear with the highest ratio is the way to, and that is normally first.
    ---Life without geometry is pointless.---
    Regular Member ludini's Avatar
    225
    always nuetral, turn the wheel in so i go into the kerb, to lazy to put into a gear, this mechanic i sometimes go to puts it in first and when i start up i always almost end up hittin the wall in front lol.
    1,488
    Yeah my mum left my car in first in my completely flat garage, and I have to park less than 10cm away form the wall to be able to open my door due to steel work bench on the side... kicked it over standing out of the car and almost shat myself, it *touched* the wall
    And fintelboss, that one just doesnt work for me. Seems to me more the end just wouldnt turn over, effectively stopping the car from rolling (though agreed it would put stress on it, but meh i'd rather than than rolling away)
    Gold Member lude_dude's Avatar
    Nissan Sextrail ST
    2,374
    i have to agree with knickers at this stage. how the hell does the engine start 'turning over', dont you need ignition for that?
    1,488
    I'm only saying I don't think it can turnover backwards, however yeah if the ignition isn't on then then nothing is going to spark..
    Oct 2007
    220
    nope, it just like a roll start. like i said its hard to do, but i think its bad for the engine to be stressed backwards. (ie when in first and parked facing up hill) i also said ive never rebuilt a car engine, so im not sure, maybe bob can settle this? it may be well be fine! and its probably better to wreak the engine then have your car roll backwards down a big hill and get written off anyway
    1,488
    You have to have the ignition on to push start a car man, also I think theres more chance of the car sliding down a hill steep enough to move the engine from 0 when the car is in gear?
    Oct 2007
    220
    when i say rotate the engine backwards, i dont mean it actually starting by itself, obviously you cant do that... all i mean is having it turn over with carmshafts etc rotating the wrong way once or twice, or simply trying to and putting a stress on all the components that it was never designed for.
    1,488
    Sadly I like you don't know enough about the pure mechanics of it, so I don't know if that could possibly happen
    Nissan Sextrail ST
    2,374
    Quote Originally Posted by fintelboss View Post
    AHA! yes, because car engines are a lot more complicated than outboard motors
    Junior Member Bekah's Avatar
    Oct 2007
    63
    Quote Originally Posted by 94vtirozguy View Post
    I do the same
    Why do some of you leave your car in neutral, doesn't it put more pressure on the hand brake?
    Gold Member Connections's Avatar
    2,408
    Gear 1 is what i all ways parked in..
    or some times reverse...
    never parked in manual in neutral ...
    sucks my new car is AUTHOE have to park in DRIVE :S
    My Cars
    5.2001 BMW e46 320I Executive [SOLD]
    4.1997 Honda Integra [sold]
    3.1994 Honda Prelude SI [sold]
    2.1989 Honda Prelude SI [sold]
    1.1993 Mazda Mx6 Gen2 [sold]
    [SIZE="1"]
    Automotive
  1. Shifting Technique
    By skinnyboy in forum General Prelude Discussion
    Last Post: 24th October 2007, 03:56 AM
  2. Gear Box Problem
    By skooda402000@hotmail.com in forum Fourth Generation
    Last Post: 9th April 2007, 01:01 PM
  3. First gear poping
    By Uwert in forum General Prelude Discussion
    Last Post: 3rd April 2005, 06:31 AM
