Results 1 to 15 of 17
    PA Janitor racinghonda's Avatar
    Jul 2005
    2,509
    EPA Victoria Modified Vehicle Guide
    MODIFIED VEHICLE GUIDELINES 2006
    TECHNICAL GUIDELINES FOR AIR AND NOISE EMISSION REQUIREMENTS
    FOR MODIFIED IN-SERVICE VEHICLES
    This is an important and valuable resource for us modders if we would like to keep on the right side of the law.
    Download/View Document
    It covers topics such as intakes, intake filters, engine modifications, ECU, exhaust manifolds (header), exhaust, turbos, PCV, fuel systems (injectors, pumps).
    Tuffcorator xmkydx's Avatar
    1,978
    genius, this should stop alot of un needed threads getting created recoving topics :p
    good work i shall browse and see if i have anything to worry about when i get pulled over next...
    edit cos i read it! -
    you can have a pod (dry type only) or an intercooler.......but not both! lol, stupid.
    also, no after market intake plenums, throttle bodies, or injectors? these are like the second tier of mods people do really...
    everyshow car in the world with engine work is defectable :p
    PM me for all your car audio and other miscellaneous installation needs.
    66
    yea its pretty insane you can't do much.
    Senior Member Prelude's Avatar
    Mar 2008
    532
    Great find! But it's pretty restrictive, some of the more subtle mods i had planned can be canned if I were to go 'by the book'!
    Zimbabwe...
    Junior Member ITZTRU's Avatar
    4th Generation
    73
    but plenum/throttle body/fuel were my next mods!
    i didn't know plenum was defectable...
    pfft...whatever...i'm still doin it...
    Now...
    http://i7.photobucket.com/albums/y267/ITZTRU/forumssignatureimagetrial2.jpg
    ...It Really "IS" True!
    Regular Member nounderscore's Avatar
    Mar 2008
    247
    anyone know if tehres a nsw one around?
    Junior Member Morgan's Avatar
    Dec 2008
    65
    I'm being screwed by this right now, I've got a 300rwkw+ single turbo Soarer and have just found out the car basically needs to be returned to stock to pass the test, I have to remove EVERYTHING...
    Single turbo kit, ECU, injectors, fuel pump, cams, cam gears, boost controller, FMIC ect ect... What a PITA.
    The plan is to remove EVERYTHING, replace with stock parts, sell all my aftermarket parts off, sell the car as a stocker and get a clean 5th Gen. It's gonna be a fun Christmas.
    JDM fanatic !JonZap!'s Avatar
    Flying Broomstick
    2,686
    which cop got you??
    Imitation is the best form of flattery
    Regular Member angrylarry's Avatar
    442
    can engineering certificates get around any of these rules? one would assume if an engineer says it's safe/done correctly it'd be alright...right?
    Dec 2008
    65
    Quote Originally Posted by angrylarry View Post
    Mechanically they can, but the issue isn't really a roadworthy one, basically ANY mod you do that will increase emissions over stock isn't standard and passing EPA is impossible.
    So, no fuel pump, fuel pressure reg, fuel injectors or tune-able ECU, then you have to keep factory configuration turbos and only one induction mod lol.
    Quote Originally Posted by !JonZap! View Post
    which cop got you??
    I live in Knox, take one guess... lol
    Morgan can't wait to fit some suspension mods
    Gold Member lude_dude's Avatar
    Nissan Sextrail ST
    2,374
    ^Are you up this late removing mods? lol
    Dec 2008
    65
    Nar, off work currently with a work cover injury, so I've become quite the insomniac hahahaha.
    Dec 2008
    65
    Hey guys, had my EPA inspection today.
    It was the first EPA test I've done at the new places, tests used to be conducted at the actual EPA in Mcleod, now they have commissioned 2 workshops to do it, at the workshop today they were a lot more thorough than they used to be, car up on the hoist, checking for EVERYTHING, I asked to be present while they tested it and he asked me "Have you modified you EGR valve?"
    I had never been asked that in the past, Soarers don't have them but it was on his list of things to check, I noticed that was a mod on here that people do in the FAQ section, just letting you guys know so that you don't go there thinking "Nar mate, she'll be sweet" and failing your test.
    TYPE SH Prelude
    It used to be that meeting emissions standards resulted in severe reduction in Hp .Like in case you did not know for example , the 1975 Corvette with a 7 liter V8 engine only add a output of 150 HP.For comparison purposes thats like a 2.2l engine with 50hp . lol Thanks to computer technology the reduction of HP due to meeting emissions standards as been reduced to a trivial level .During cruising , a modern engine runs in what is called a closed loop mode which runs the engine as lean as possible and its emissions output very clean.When you floor it , the ECU goes open loop , and the engine runs at maximum output with out any concern for emissions.In 1983 they could not do such a thing with the 3 barrel carburetor that was on the 2nd gen lude for example so performance suffered for the sake of emissions. In the recent past I have herd of situations where people have removed their cat with bad results. They get a slight gain in top end power while their low rpm power goes to hell because their engines are designed to need that cat back pressure at low rpms.By restricting what you can replace on your engine in a real sense is saving people from spending lots of money on aftermarket enhancements that only give marginal improvements.
    Also if you should get in a major accident that results in major claims , the insurance company can refuse to pay and leave you holding the bag if they find you have an illegally modified car whose HP is significantly more then the car they thought they were insuring .Remember insurance companies make money by not paying claims !
    Gold Member gumus89's Avatar
    Jan 2008
    2,321
    Quote Originally Posted by Morgan View Post
    Did they believe you? Or did they look for your non-existant EGR valve?
    <a href=http://www.preludeaustralia.com/forum/showthread.php?t=42730 target=_blank>http://www.preludeaustralia.com/foru...ad.php?t=42730</a>
    Back to it's former glory... Almost.
  1. Suspension Information
    By Mugen_Dreams in forum Suspension / Wheels / Tyres / Brakes
    Last Post: 8th February 2005, 11:36 PM
