Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
    3rd Gen Specifications
    Built by Honda in Japan from: 1987(April) to 1991 (Sep)
    Australian deliveries from Sept 1987
    If you have any specs on the 3g which are useful post them up her and I'll start to compile a single post reference.
    Call it a work in progress.
    3g Parts Catalog
    http://www.prelude3g.com/
    Models:
    Series 1: 1988-1989
    Series 2: 1990-1991
    AUD models (KQ):
    Si: Power sun roof, Cruise control, Power mirrors, Alloy wheels, Central locking, Power windows, Power steering, Radio cassette.
    Cita:
    Cita Luxury: Leather, ALB
    JDM Models: Honda JDM Listing- not complete
    http://translate.googleusercontent.c...ONYHx05QSQeblA
    XX
    TCV
    INX
    SI States
    USDM Models:
    Suspension:
    Standard tyre rim tyre size: 14x5.5" Rim, +45mm offset, 195/60/R14 tyre.
    Min Load rating - 85
    Speed rating as per ID plate - V.
    Stud pattern: 4x100, M12x1.5.
    Std "89 Alloy rim weighs 8.4kg (18.5lb)
    Double wishbone front and rear
    Mechanical 4WS
    Ground Clearance (Stock) 150 mm
    Stock Sway Bars: Front 25.4mm (Hollow), Rear 17mm (Whiteline Sway bars - Front: 24mm, Rear: 20mm)
    Brakes:
    Front: Ventilated discs, Pad DB1133
    Rear: Non-ventilated discs, Pad DB1163
    Engine:
    Ref: http://en.wikipedia.org/wiki/Honda_B20A_engine
    All fuel injected 3gs use peak and hold 240cc injectors
    Standard flywheel weighs 9.5kg (21lb)
    88-91 OBD0 with a PK2 ECU (applies to all B20A series engines)
    90-91 OBD1 with PK3 ECU (USDM Only with B21A)
    Distributor is OBD1 compatible (24 Teeth) on all fuel injected 3rd gens
    B20A6 (AUDM)
    Compression 9.4:1
    106kW(142HP)/6000rpm
    174.4Nm/4500rpm atfw
    EXACT Stock 3g and b18 Camshaft Specifications
    http://www.preludepower.com/forums/s...d.php?t=242616
    exact stock 3g intake mani specs
    http://www.preludepower.com/forums/s...d.php?t=254142
    ECU Error codes:
    '88-'91 PGM-FI (OBD0)
    Code 0 ECU
    Code 1 Oxygen content A
    Code 2 Oxygen content B
    Code 3 MAP sensor
    Code 4 Crank angle sensor
    Code 5 MAP sensor
    Code 6 Coolant temperature
    Code 7 TPS sensor
    Code 8 TDC position sensor
    Code 9 No.1 cylinder position sensor
    Code 10 Intake air temperature sensor
    Code 11 Idle Mixture Adjustment sensor
    Code 12 Exhaust gas recirculation system
    Code 13 Atmospheric pressure sensor
    Code 14 Electronic idle control
    Code 15 Ignition output signal
    Code 16 Fuel injector
    Code 17 Vehicle speed sensor
    Transmission:
    Options were 5speed manual or 4speed auto.
    Code: D2J5 Manual (Series 1)
    1 = 3.166__58.1 km/h @ 7000rpm
    2 = 1.857__100.1 km/h @ 7000rpm
    3 = 1.259__147 km/h @ 7000rpm
    4 = 0.935__196 km/h @ 7000rpm
    5 = 0.794__231 km/h @ 7000rpm
    Reverse = 3.000
    Final Drive = 4.062
    Code: D2M5 Manual (Series 2)
    1 = 3.307
    2 = 1.809
    3 = 1.230
    4 = 0.964 (Taken from the manual)
    5 = 0.812 (Taken from the manual)
    Reverse = 3.000
    Final Drive = 4.062
    Series 1 Auto Code?
    1 = 2.529
    2 = 1.444
    3 = 1.030
    4 = 0.725
    Reverse = 1.904
    Series 2 Auto Code?
    1 = 2.647
    2 = 1.392
    3 = 1.060
    4 = 0.763
    Reverse = 1.904
    Chassis:
    Code BA4, BA5
    Claimed Cd 0.34
    Dimensions in mm
    Wheelbase 2565
    Front track 1480
    Rear track 1470
    Length 4460
    Width 1695
    Height 1295
    Turning Circle 9.6 m
    Tank Capacity 60 litres
    Kerb Weight 1130 kg (manual)
    Towing Capacity 400 kg
    Interior:
    Dimensions in mm
    Dash panel to rear seat 1540
    S/wheel to seat (min/max) 510/700
    Pedals to seat (min/max) 340/520
    Rear legroom (min/max) 90/280
    Shoulder width, front 1300
    Shoulder width, rear 1300
    Front cushion depth 520
    Front cushion height (min/max) 240/270
    Rear cushion depth 440
    Rear cushion height 280
    Load Space
    Floor length (seat up) 1060
    Floor length (seat down) 1610
    Floor to lid (min/max) 340/430
    Lip to lid 620
    Opening depth 430
    Opening width 1290
    Loading height 860
    Floor width (max) 1640
    Floor width (between arches) 860
    Exterior:
    Colours
    Laguna Gold - YR-87M
    Melbourne Blue - B-50M
    Granada Black - NH-503P
    Noble Silver - NH-516M
    Phoenix Red - R-51
    Navajo Red - R-70M
    Shannon Grey - G-59M
    Polar White - NH-512Z
    Charcoal Granite - NH531M
    Series 2 colours
    Frost White - NH538
    Laurel Blue - B49M (possible series 1 colour too)
    Bordeaux Red - R78P
    Electrics:
    H4 Headlights
    H3 Optional OEM Fog lights
    T10 Front Parkers
    S25 (1157) Reverse light
    S25 (1157) Brake light
    S25 (1156) Indicators
    T10 Cluster speedo section's
    T5 Cluster,the part on top of the cluster, cluster lights above speedo, ignition key light, ciggie lighter, gear selection area on Auto's only, ashtray light
    T4 Air con knob thing and 4ws button
    T3 All aircon buttons, cruise control, demister. sun roof open close button and last but not least the hazard warning light
    Complete interior LED conversion
    d2m5 manual tranny from sII
    1 = 3.307
    2 = 1.809
    3 = 1.230
    4 = 0.935
    5 = 0.794
    R = 3.000
    FD = 4.062
    no idea what the speed is in each gear... but close ratio 2nd and 3rd ftw
    Paint codes: (only know the colours for the 2 i've had)
    YR-87M Laguna Gold Metallic
    NH-512 Polar White
    and the B20A6 is actually 9.4:1 CR
    Silver Member AYRTON's Avatar
    Si-TCV
    Aug 2005
    1,677
    Si-States is a JDM model.
    04' Euro Luxury
    89' Prelude Si-TCV - crème de la crème of Prelude's
    PM me if you're interested in buying it.
    Regular Member Martzy's Avatar
    152
    Colour NH - 516M - Nobel Silver Metallic
    Also you might just want to change the year when 3rd started to something like September 1987.
    Im not too sure about the compression ration. Richard quotes 9.0:1 on his racinghonda site. Needs verification
    from page 3-14 of the service manual.
    AUDM 3rd gens are KQ
    9.0 gets quoted alot on American forums, you'll find that the B20A5 is 9.0
    Thanks Ian. Love your work.
    [R-51] Phoenix Red
    And some more.... lol
    From the sales brochure
    Paint colours
    Phoenix Red - R-51
    Navajo Red - R-70M
    And the series 2's had
    Frost White - NH538
    Laurel Blue - B49M ( I think this was a series 1 colour too??)
    Mar 2008
    Quote Originally Posted by Martzy View Post
    yes mine also is 3Generation , 1989 charcol granite !
    Somehow theres one colour that always gets missed for the series 2 3g:
    R-78P Bordeaux Red, thats the series 2 burgundy. (theres no option for this code when signing up to PA!)
    Leather Interior code is "Interior colour: Type E"
    Also - There are a few series 2's out there that missed all the Cita options (CD player, floor mats, rear spoiler and badges) but got the leather and the ALB.
    Junior Member chamolluscug's Avatar
    JDM
    Jan 2008
    73
    Hey my JDM has chassis code E-BA5??
    P plater = restrict car to 200kw = need to get to 200kw well, as close to 200kw as a B20 gets lol
    Can someone please verify if the 90-91 S2 uses a PK2 ECU? This will indicate if it is OBD0 or OBD1.
    yes it's pk2, i have a dead pk2 from a 91 sitting in my pile of prelude crap in the shed.
    Cheers, So ALL B20A series engines in the 3g are OBD0. There was never an OBD1 ECU 3g in Australia.
    Only the B21A in the US received the OBD1 PK3 ECU.
  1. 4th gen interior into 3rd gen..
    By aznkim in forum Third Generation
    Last Post: 21st September 2009, 11:17 PM
