Page 24 of 103 FirstFirst ... 1422232425263474 ... LastLast
Results 346 to 360 of 1540
  1. #346
    Premium Member AMPERAGE's Avatar
    VTi-R
    May 2006
    2,261
    Question:
    When changing out the rods and pistons, inevitably changing the reciprocating mass of the engine in comparison to stock, how does this affect the action of the balancer shafts? (I'm making the assumption that the H23, like the H22, has balancer shafts.) The shafts are weighted to work with a specific reciprocating mass and changing this mass will evidently cause the balancer shafts to be incorrectly weighted to counter measure this reciprocating mass.
    AMPERAGE
  2. #347
    Gold Member hiru's Avatar
    Other Honda
    Nov 2006
    3,231
    would this be compensated for when the crank gets re-balanced with the pistons and rods connected? (does this even happen? I know the crank gets re-balanced but I dont know enough as to whether this is with or without rods and piston heads)
    Just my thinking?
  3. #348
    Quote Originally Posted by hiru View Post
    Just my thinking?
    if balancing is done properly it will be done with everything that attaches to the crank in place
    piston, rods, crank pulley, flywheel, clutch pressure plate
  4. #349
    Its all happening!
    Pistons/rods are down at the engine shop. He said I should get the block back by the end of next week!
    The entire rotating assembly will be balanced. The block is being bored out .25 and then honed.
  5. #350
    Header wrapping the dump pipe. About to wrap the turbo manifold.
    Intercooler installed!
    I cut the factory lower radiator mounts off a wrecked prelude, then drilled and bolted them to the front crossmember in the right place. The cooler sits nicely in the factory rubber grommets!
    The top mount is a bracket made of aluminium with another "L" bracket off the lower bolt from the hood latch. This was a pain to get right, but I think the end result speaks for itself. The cooler sits sturdy as a rock. And the piping will clear the bumper without any cutting/modification.
    I'm retaining the A/C and the JDM foglights
  6. #351
    good job on the intercooler mounting
  7. #352
    PA Resident SAKI's Avatar
    May 2006
    3,987
    Nice to not have to sacrifice your AC
    It may be just a wild internet rumour, but doesnt thermal tape attract moisture causing rust?
    Quote Originally Posted by brash22 View Post
    You sir are mad. Like lock you in the nuthouse mad.
    Quote Originally Posted by Manabir View Post
    You sir are a prelude obsessed freak.
    you sir, are a prelunatic.
  8. #353
    Silver Member Seismic's Avatar
    Custom
    Jun 2004
    1,350
    Copy cat!!! Haha, noice - VERY noice!
    Did you end up deciding to keep the balancer shafts?
    And you've gone +25 bore I see. What psi are you planning to push with these puppies?
    The path of Honda is beset on all sides by the iniquities of Mazda and the tyranny of Nissan. Blessed is the Honda owner who in the name of handling and performance shepherds his Honda through the valley of darkness, for he is truly his Honda's keeper and the finder of lost kilowatts. And I will strike down upon thee with great acceleration and furious VTEC those who attempt to overtake and destroy my Hondas. And you will know my name is PRELUDE when I lay my VTEC upon thee.
  9. #354
    Quote Originally Posted by PJF_Lude View Post
    Thanks for the help bud - appreciate it!
    Quote Originally Posted by SAKI View Post
    Its stainless steel + ceramic coated + painted with 100% silicone paint...
    Rust? what rust?
    Quote Originally Posted by Seismic View Post
    I cant help that Mahle are the only supplier of pistons for a H22 (without resleeving). And Pauter makes the best H23 rods available.
    I'm keeping the balancer shafts.
    Yup, +.25 bore. No limit on the PSI. I'll stop pushing it when it stops making power...
    or when I cant supply it enough fuel...
    or when the EGT's get too high...
  10. #355
    PA Janitor Bob's Avatar
    Si 4WS - B Spec
    Jan 2006
    11,090
    When it goes boom just wind it back a few pound.
  11. #356
    Senior Member TonyD's Avatar
    Other Honda
    2.0 Si
    Apr 2008
    566
    Quote Originally Posted by Bob View Post
    Nah mate she'll be right, just push a few more PSI. She can handle it.
  12. #357
    SHHHH! no talk of anything going "boom" in my thread thanks. Nothing will go "boom".
    Honestly though PSI doesnt matter a fig. Let me explain.
    Big turbo + 10psi = 2x as much air as Small turbo + 10psi...
    If someone comes up to you and says I'm running 10pounds of boost I'm awesome. You should ask them for the size of the compressor wheel before you say "wow, you really are awesome!".
    A horsepower goal is a much better thing to ask.
  13. #358
    May 2006
    3,987
    Quote Originally Posted by AdReNaLiN View Post
    Rust? what rust?
    Oh yeah... lol.
    Is there actually a power figure you are aiming for? Or is this just a case of as much as possible
  14. #359
    Lol! I knew someone would ask.
    I'll be happy with 250hp. And over-the-moon with 300
  15. #360
    250hp, nigga please, i know the real goal, but have been sworn to secrecy
