Page 30 of 103 FirstFirst ... 2028293031324080 ... LastLast
Results 436 to 450 of 1540
  1. #436
    Silver Member Seismic's Avatar
    Custom
    Jun 2004
    1,350
    Quote Originally Posted by PJF_Lude View Post
    easiest way would be to check the impedance with a meter
    True - Impedance for 550C p&H RC injectors should be 2.5 ohms
    The path of Honda is beset on all sides by the iniquities of Mazda and the tyranny of Nissan. Blessed is the Honda owner who in the name of handling and performance shepherds his Honda through the valley of darkness, for he is truly his Honda's keeper and the finder of lost kilowatts. And I will strike down upon thee with great acceleration and furious VTEC those who attempt to overtake and destroy my Hondas. And you will know my name is PRELUDE when I lay my VTEC upon thee.
  2. #437
    Got stuck into wiring up the motor on the weekend - here's a sneek preview at my wire-tucking efforts...
    I'm trying to do it with the least possible amount of extending wires. However I am re-wrapping everything with flame retardant braided wrap.
    I then got stuck into my valve cover and painted the lower engine cover. Here's how the timing belt side of the engine will pretty much look when the car's done.
    And the valve cover.
    I then installed my oil feed line for the turbo. Its an adaptor for the factory oil pressure sensor port. The factory sensor is then installed into the back of it.
    Enjoy.
  3. #438
    Custom
    Jun 2004
    1,350
    I'm sounding like a stuck record but that's nice work man!
  4. #439
    Thanks Shane! I really wanna get the valve cover as smooth as glass. Its gonna get 6 coats of clear coat and a shitload of wetsanding
  5. #440
    Gold Member peejayy's Avatar
    Nov 2006
    2,715
    why did you paint the plastic lower engine cover? isnt it black anyway? personal preference i suppose. i like the wire tucking efforts.
    whens the expected completion date?
    m:0432 699 951 e:pujitha115@optusnet.com.au msn:peejayy@hotmail.com
  6. #441
    Quote Originally Posted by peejayy View Post
    It is normally black. I painted mine gunmetal grey. And if you'd ever seen an enginecover off a motor that'd been on a car for more than 10yrs you'd wanna paint it too. It was filthy and no amount of degreaser/cleaning was going to get rid of the grease stains.
    Expecting to have the engine in and running before christmas.
  7. #442
    Nov 2006
    2,715
    hmm, fair enough! thats funny though because my lower engine cover is spotless!
  8. #443
    Gold Member phattzy's Avatar
    si 4ws TURBO
    May 2009
    2,981
    ah that took half the day to read that and im very interested in how it performs ? 10:1 c/r seems a little high for forced inducted i gather you with only run low psi . i remember when i put that gtk on mine standard c/r 9:1 10psi and blew head gaskets like no tomorrow . instal 1.6mm 304 decomp plate 10psi and ran awesome . except the rod bending . youve done a heap of work 10/10 ive got nothing but good comments . i hope your going to get a half decent fpr ? i got a sard of the net for $135 in wa . well worth it . top stuff champ
    GARAGE : http://www.preludeaustralia.com/foru..._vehicle&id=30
    BUILD THREAD : http://www.preludeaustralia.com/foru...o-3rd-gen-lude
    VIDEOS
    http://www.youtube.com/watch?v=usazsV_c_zU
    http://www.youtube.com/watch?v=psgNZjLqRrw
    http://www.youtube.com/watch?v=BRn-1Oeashw
    Quote Originally Posted by SAKI View Post
    PS: Can't wait to see your beast in action.. going to be one the highest power 3rd gens out there i reckon..
    Quote Originally Posted by Pacman View Post
    I am going down now to show them mine....
  9. #444
    So over the course of the week I happened to come into some fortune and obtained two rather nice chunks of polished aluminium. I'll let the pictures do the talking.
    Aluminium Radiator. Thanks MattyK!
    EGR Blockoff Plate. Thanks Ian!
  10. #445
    Custom
    Jun 2004
    1,350
    Dayum!!! That looks good! Did Ian fab the plate for you? I was just looking at a blockoff plate on eBay, US$7 but the freight is probably gonna be $30!
  11. #446
    Ian has what's known as a "copyrouter" at work. It allows you to machine a copy of a template into a new chunk of metal.
    After breaking the routing bit on the router, I'm not sure how keen Ian is to try making more...
  12. #447
    Premium Member AMPERAGE's Avatar
    VTi-R
    May 2006
    2,261
    The better method for EGR block-off is to install a plate like that but re-install the EGR valve on top of it. If you do not re-install the EGR valve and sensor connector you can throw a CEL light and ECU codes.
    I've run without a functioning EGR valve for 2.5 years, by removing the EGR valve from the intake system but leaving the EGR valve connected to both the vacuum system and electrical system and it's never thrown a CEL or ECU code.
    AMPERAGE
  13. #448
    the EGR can be turned off with the tunable ECU, it won't be a problem, and the plate i made looks far better
    Quote Originally Posted by Seismic View Post
    I can make you one for $38
  14. #449
    VTi-R
    May 2006
    2,261
    Quote Originally Posted by PJF Lude
    Good stuff. I've wanted to get rid of mine for ages too. I'm still waiting for James from Hondata to make another trip back over to Perth.
    AMPERAGE
  15. #450
    True dat. I've been fapping away over it while we speak...
    Fap fap fap...
