Page 29 of 103 FirstFirst ... 1927282930313979 ... LastLast
Results 421 to 435 of 1540
  1. #421
    Administrator azjs's Avatar
    Nov 2002
    2,381
    Nice work, so rejigging the bracket for the dump pipe caused no dramas?
    -az
    B68-P 4th Gen Si - Tuned H22, Tuned Chassis, Detuned Driver
  2. #422
    I ended up cutting it off, it just wouldnt fit.
  3. #423
    Gold Member peejayy's Avatar
    Nov 2006
    2,715
    and all this is going to fit back into the engine bay right?
    that wouldbe the biggest anti-climax ever!
    jk mate, keep the pics coming!
    m:0432 699 951 e:pujitha115@optusnet.com.au msn:peejayy@hotmail.com
  4. #424
    Silver Member Seismic's Avatar
    Custom
    Jun 2004
    1,350
    Wow man! Very nice - loving your dedication to the finer details too!
    The path of Honda is beset on all sides by the iniquities of Mazda and the tyranny of Nissan. Blessed is the Honda owner who in the name of handling and performance shepherds his Honda through the valley of darkness, for he is truly his Honda's keeper and the finder of lost kilowatts. And I will strike down upon thee with great acceleration and furious VTEC those who attempt to overtake and destroy my Hondas. And you will know my name is PRELUDE when I lay my VTEC upon thee.
  5. #425
    It'll all fit in the enginebay...
    Thanks for the kind comments guys.
  6. #426
    I picked up my gaskets yesterday afternoon to continue installing the intake manifold. Here she is!
    AEM Fuel Rail
    RC 550cc Injectors
    POWER 68mm Throttle Body
    Omni Power 3bar Map Sensor
    Gates Racing Thermostat
    And something I've been working on for a little while now. The valve cover with breather mods. I'm also smoothing all the casting marks and stuff off so when its painted it should look as smooth as glass.
    Enjoy.
  7. #427
    Nov 2006
    2,715
    everytime i see this thread float to the top i get excited!
    your definitely delivering with pics! The breather mods are interesting and will be well worth it. Care to explain the logic behind it?> Just bigger = better?
  8. #428
    The AN fittings will be hooked up to braided hoses running to a catch can setup as described here:
    http://www.preludeaustralia.com/foru...&postcount=310
    The PCV system will not be implemented as standard as when the engine is on boost, the recirculation of gas is prevented due to the PCV valve closing up.
  9. #429
    Nov 2002
    2,381
    Man that fuel rail looks mean! Looking forward to the rest of the AN fittings...
    -az
  10. #430
    Custom
    Jun 2004
    1,350
    Hey Steve, your H22a head is an OBD1 right? So the RC injectors are peak and hold? Running with the stock resistor box? Or have you gone to saturated and removed the resistor box? Or have you done something funky with your Chrome setup to run the P&H properly?
  11. #431
    The vtec head is ODB1. Came from a 1992 JDM lude.
    Injectors (as far as I'm aware) are peak and hold and am going to run the stock resistor box. Nothing funky with crome besides adjusting the fuel maps to allow for the bigger injectors.
    You've made me want to double check the part number to make sure they're peak and hold now. They do plug directly into the honda wiring harness with no modification to the clips.
  12. #432
    PA Resident SAKI's Avatar
    May 2006
    3,987
    Fittings = hot
    What colour is the cover going to be?
    Quote Originally Posted by brash22 View Post
    You sir are mad. Like lock you in the nuthouse mad.
    Quote Originally Posted by Manabir View Post
    You sir are a prelude obsessed freak.
    Quote Originally Posted by hiru View Post
    you sir, are a prelunatic.
  13. #433
    Valve cover is gonna be Frost White - same colour as the car.
    The spark plug cover will be gunmetal grey metallic.
    The fittings are going to be recoated gunmetal also.
    The valve cover will have moon cuts to access the adjustable cam gears...
  14. #434
    easiest way would be to check the impedance with a meter
  15. #435
    Senior Member Cam's Avatar
    Oct 2007
    543
    hot as always mate, love what you're doing! Keep the pics coming!
