Page 73 of 73 FirstFirst ... 2363717273
Results 1,081 to 1,086 of 1086
  1. #1081
    Just for fun pull out into traffic with a bit of jest. Shifting to 2nd gear. Box full of neutrals no go and no sign of any damage. Quite lucky not to get rear ended. Tow truck ride home.
    Get it home, jack it up and quickly find the issue.
    Driveshafts usually spin with the wheels, but in this case I seem to have blown the outer CV joint.
    Quick fix. Buys a lotto ticket.
    But it does point out that with a helical LSD and one wheel with no grip will not transfer power at all to the other side.
  2. #1082
    Inspection. Cage separated into 2 parts.
  3. #1083
    it happens :S could have been worse
    Happy it never happened to me
  4. #1084
    882
    Not good . S2 box with 36mm drive shafts incoming?
  5. #1085
    Stock replacement shaft installed. I'll give it another go as is. If it ends up a repeat failure issue I'll go Gator or similar.
    I don't believe the size of the shafts is the issue. I suspect it's simply quality (Made in China) and strength of the CV's.
  6. #1086
    882
    Yeah, fair enough. It wasn't actually the shaft at all!
  1. Replies: 54
    Last Post: 9th February 2013, 09:30 AM
