Page 3 of 73 FirstFirst 123451353 ... LastLast
Results 31 to 45 of 1086
    Mugenator skinnyboy's Avatar
    Hybrid S and VTiR
    Apr 2005
    3,036
    Silver Member AYRTON's Avatar
    Si-TCV
    Aug 2005
    1,677
    nice work bob.. look forward hearing more about your progress..
    04' Euro Luxury
    89' Prelude Si-TCV - crème de la crème of Prelude's
    PM me if you're interested in buying it.
    ARP Head Stud kit arrived.
    Part Numbers are
    2 off *ATP7.675-1LUB
    8 off ATP6.350-1LUB
    10 off 7/16 12pt nuts
    10 off 7/16 washers
    Purchased directly from ARP.
    BTW if you need studs for the main caps I am told, it is the same as for a H22, H23.
    Part # 208-5401
    None of the above come with nuts or washers
    Obviously tell them you need the corresponding ARP nuts and washers.
    ***You have to use ARP washers/nuts with ARP Studs/Bolts
    These are a fantastic product and I could not recommend these more highly.
    I will be using a copper gasket with Hylomar Blue compound to help seal it.
    Trial fit pics
    Short bolt
    Long bolt
    Gold Member Lawson's Avatar
    2,113
    thats sexy man, are you finding any trouble's with bits left over? like "where the f**k did this bolt come from" when your putting it back together?
    Senior Member ludemobile's Avatar
    2.0 Si 4WS
    Apr 2004
    866
    Very nice! I didn't know honda discontinued the head studs for our blocks. How long was the wait and how much was everything all up? Btw did you get a thicker head gasket since it's copper?
    Quote Originally Posted by Lawson View Post
    Well considering I bought it in bits, that is a small concern. But I'm not in any rush. So I should be able to put it together without too much fuss.
    Quote Originally Posted by ludemobile View Post
    I was told at the service counter that they no longer stock them in Australia. I can only assume people are reusing the old ones. It didn't take much to twist my arm to get the ARP set though. I think its damned good insurance for a boosted setup.
    The copper head gasket is actually slightly thinner than the OEM gasket however it will not crush as much.
    Cost...243USD including 97USD freight.
    Regular Member loode88's Avatar
    Austrailia
    409
    Thats looking good..how come the oil/water wells dont match up with the gasket?
    PA Resident Flipmods's Avatar
    3,513
    Great stuff Rob. Good to see you found ARP bolts as I couldn't find them when I was looking for them. A must for the setup you are running, I think you can push 22-25psi safely with that setup.
    Honda sell the bolts but take a couple of weeks to get here from Japan and cost close to what you paid for the ARP's.
    Keep up the good work.
    BRING BACK THE FORUMS!
    2,261
    I would like to caress your head studs caringly.
    AMPERAGE
    Quote Originally Posted by loode88 View Post
    The copper gasket is an exact copy of the Honda OEM one. I have checked it. I understand that it is designed to restrict some of the flow through the head.
    Quote Originally Posted by Flipmods View Post
    Cheers mate.
    Quote Originally Posted by AMPERAGE View Post
    You can come and touch my studs anytime, (you naughty boy).
    Well its assembled and torqued up to OEM specs.
    Edit: Retorqued to 22ft.lb followed by 49ft.lb then 62ft.lb with ARP moly lube.
    Hylomar reference.
    http://www.scegaskets.com/techtips/top10.html
    http://www.hylomar.com/universal_blue.shtml
    The head is o-ringed.
    The distance from the seat to the top of the center stud is 16.5mm. This gives 5mm clearance to the cam.
    I received confirmation from ARP and they are in the process of setting up the part number for the set. I'll let you know what it is when I find out.
    Short studs
    Long studs
    Regular Member Prelude_ftw's Avatar
    294
    You seem to know just about everything with the 3rd gen bob. I have no doubt ur finished project will be insane. Looking good so far.
    PA Janitor racinghonda's Avatar
    Jul 2005
    2,509
    Nice one Bob.
    Lol I finally know what getting a head o-ringed means!
    Also, from the below pic, it looks like the gasket holes don't quite match the water jacket holes on the block? Is that normal?
    My understanding is that the gasket acts to restrict and control the flow of fluids through the head. Its an exact copy of the OEM gasket.
    3,513
    Quote Originally Posted by racinghonda View Post
    Nice one Bob.
    I checked it too and it is same as stock.
    Edit: you beat me by 1 min Bob
  1. Replies: 54
    Last Post: 9th February 2013, 08:30 AM
